Topic: Now Hiring! (Read 10359 times) previous topic - next topic
retrolefty
Hi All
I am still looking for anyone to help with the code for my project.  One again,  this is a PAID gig.  I am one week away from the due date and is still in the testing stage.  I can drive the servos and I can test the sensors using the serial monitor but is yet to have the sensor and the servo working together.
It's been almost three months sense your original posting and with one week to blast-off, I assume it's not going to happen you you.
Lefty
mmcp42
#801 here
I'll take a look
you can PM or email me
cheers
Mike
PS UK based, but electrons get everywhere!
there are only 10 types of people
them that understands binary
and them that doesn't
mmcp42
hmm
emails are bouncing
very strange
The original message was received at Mon, 23 Jan 2012 21:30:58 GMT
from localhost.localdomain [127.0.0.1]
   ----- The following addresses had permanent fatal errors -----
<electric_al@hvc.rr.com>
    (reason: 550 5.1.1 - Invalid mailbox: electric_al@hvc.rr.com)
graynomad
It looks like jumpjack tried to contact you.
I'm sure there's many people who are happy to help with a specific problem, maybe those that can do the work are already occupied.
If I read correctly you need to
run for 4 seconds
return to start
run for 8 seconds
return to start
run for 12 seconds
return to start
run for 16 seconds
return to start
Is that it?
______
Rob
CrossRoads
No, he wanted to use ultrasonic sensors & stuff.
graynomad
Just as an over/end of travel measure though isn't it?
______
Rob
electric_AL
hi All, email addy is good, just gave Time Warner Cable a piece of my mind.
this is correct:
run for 4 seconds
return to start
run for 8 seconds
return to start
run for 12 seconds
return to start
run for 16 seconds - by now should reach end of track
then do the same from the other direction.
the sensors are to detect the end of the track.
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming
WOW!!!   What a Ride!
graynomad
What does this mean? Move to the other end then repeat the above but reversed?
______
Rob
CrossRoads
A     B    C     D      E
5 track positions
A-B-A
A-C-A
A-D-A
A-E
E-D-E
E-C-E
E-B-E
E-A
repeat
electric_AL
Exactly!
[font=Verdana]A     B    C     D      E
5 track positions
A-B-A
A-C-A
A-D-A
A-E
E-D-E
E-C-E
E-B-E
E-A
thanks
repeat[/font]
WOW!!!   What a Ride!
electric_AL
Additionally, I am also in need of an Arduino program to make a lap timer.
The board:    Mega 2560
The Sensors:  Sharp Proximity sensors = (no contact triggering is a must)
LCD display:   TBD
THe Idea: how long it takes ( seconds/minutes) for my Trolley to travel 10feet of track and display it on a lcd screen and be resettable.  Something similar to a Slot Car lap timing system.
Paid!
WOW!!!   What a Ride!
mmcp42
while I'm there I can do that as well
all integrated in one package or two separate (but related) projects?
graynomad
Here's a rough prototype of some code that should make a start.
#define SECTION_TIME 1000  // # of mS to travel a section
#define FOWARDS 1
#define BACKWARDS 0
volatile boolean stop;
void startMotors (int direction) {}; // you write these
void stopMotors () {};
void move (int sections, int direction) {
long time_to_travel = sections * SECTION_TIME;
long start_time = millis();
long stop_time = start_time + time_to_travel;
startMotors (direction);
while (millis() < stop_time && !stop) {}
stopMotors();
stop = false;
void fontSensor_ISR() {
stop = true;
void backSensor_ISR() {
stop = true;
void setup () {
attachInterrupt (0, fontSensor_ISR, RISING);
attachInterrupt (1, backSensor_ISR, RISING);
void loop () {
move (1, FOWARDS); // move to A
move (1, BACKWARDS);
move (2, FOWARDS); // move to B
move (2, BACKWARDS);
move (3, FOWARDS); // move to C
move (3, BACKWARDS);
move (4, FOWARDS); // move to D
move (4, BACKWARDS);
move (6, FOWARDS); // move to E (stopped by sensor)
move (1, BACKWARDS); // move to D
move (1, FOWARDS);
move (2, BACKWARDS); // move to C
move (2, FOWARDS);
move (3, BACKWARDS); // move to B
move (3, FOWARDS);
move (6, BACKWARDS); // move to A (stopped by sensor)
delay (1000);
It assumes that you get an interrupt from the sensors if you get too close, but now that I think about it that probably is not the case so that should be changed.
Can you use that as a start and build it from there?
I could not get onto the forum most of yesterday so didn't see the new requirements.
______
Rob
graynomad
#28
Jan 25, 2012, 04:54 am Last Edit: Jan 25, 2012, 04:59 am by Graynomad Reason: 1
Here's a version with no interrupts.
#define FOWARDS 1
#define BACKWARDS 0
boolean toCloseFront () {};
boolean toCloseBack () {};
while (millis() < stop_time) {
if (direction == FOWARDS && toCloseFront()) break;
if (direction == BACKWARDS && toCloseBack()) break;
stopMotors();
void setup () {
void loop () {
move (1, FOWARDS);
move (2, FOWARDS);
move (3, FOWARDS);
delay (1000);
______
Rob
mmcp42
just for the thread
I'm on the case now
got a solution working not too far from the method suggested by Rob (Graynomad)
