Topic: which controller can i use to connect 15 buttons (Read 3066 times) previous topic - next topic
ilinsky
hi guys sorry for stupid question
i have a task, connect to arduino 15 analog buttons, when button is pushed send info to USB
for me is interesting which controller i need to buy and how can i connect so many buttons?
Thank you very much
johnwasser
Some more detail would be useful.  What do you mean by "analog buttons"?
For regular on/off buttons, any Arduino with a USB-to-Serial adapter would do what you ask.  The Arduino UNO is the most common,
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
runaway_pancake
"Analog buttons"?  I assume by that you mean pushbuttons?
74HC165, parallel_in-serial_out shift register, "daisy-chain" two, each switch to '165 input; constantly read the shift register data.
Here's a link to someone who "got it" - http://arduino.cc/forum/index.php/topic,10069.0.html
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
justjed
There's also the analog buttons method, which could easily accomodate 15 buttons -- even on 1 analog pin, with careful choice of resistors, I think.
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
zoomkat
If the buttons are pushed only one at a time, you could use a multiplexer like below to input a single analog pin.
http://www.sparkfun.com/products/299
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
CrossRoads
If one at a time, can also wire them up like a 4x4 matrix, and connect to just 8 pins using the keypad library, no external hardware needed.
http://arduino.cc/playground/Code/Keypad
runaway_pancake
Oh-ho, Analog buttons -- there you go.
So, I guess the only "controller" ilinsky needs is any Arduino, 15 resistors (I guess), and, as far as "sending info to USB" goes, serial.print (and don't press anymore than one button at a time.)
CrossRoads
Have 18 digital I/O available outside of Rx/Tx that are commited to serial port in this case.  Use 15 of them:
D2,3,4,5,6,7,8,9,10,11,12,13,14,15,16
(A0-A5 are also D14-D19)
Why resistors at all?  Use internal pullups on input pins, buttons close to ground.
Code: [Select]
// I'm totally winging it here, may need to check the Reference page for syntax on a couple of things...
byte D[15]; // declare 15 element array
D[ ] = {2,3,4,5,6,7,8,9,10,11,12,13,14,15,16}; // map the Dx pins into the array, D[0] represents D2 ... D[14] represents D16
int x;  // variable we'll use a bunch
void setup(){
for (x = 0; x<15; x=x+1){  // setup a loop to go from 0 to 14 to access the array elements
pinMode (D[x], INPUT);  // set the pins as inputs, recall: D[0] = D2
digitalWrite (D[x], HIGH);  // enables  internal pullup
Serial.begin(9600);  // library takes care of setting D0, D1 as needed
}  // end setup
void loop(){
for (int x =0; x<15; x=x+1){  // set to read D[0] to D[14],
    if (digitalRead (D[x]) == 0){  // is a button pushed?
    value = x; // store the array index (?) that was found low, i.e. button was pushed
// now act on the button that was pushed
    switch (value){ // use this to jump to the code for the button that was pushed
case 0:
// code for D2
Serial.println(" button  on D2 was pressed");
case 1:
// code for D3
Serial.println(" button  on D3 was pressed");
//etc
case 14:
//code for  D16
Serial.println(" button  on D16 was pressed");
     } // end switch
   } // end if button pushed, go read the next one
} // end void loop
Give it a shot, see how it goes
runaway_pancake
Quote
"Why resistors at all?"
With the "Analog buttons" the 15 resistors effect 15 voltage levels to an Analog input pin (they're all different values tied HI and with contact each effects a different voltage there) - one pin versus many.
A straight digitalRead or a shift register data shift routine will probably go a lot faster though.
CrossRoads
Given that no other IO is specified, go the straightforward route: digitalReads of "[push]buttons" being Hi/Lo.
ilinsky
Great, thank you guys for great reply. well yeah is my fault to call pushbutton as Analog haha
i will try to use matrix 4X4 i guess is the most easy solution
floresta
Quote
No, the problem is that pushbuttons are being called buttons.
Don
ilinsky
Thank you a lot, now i understand more less how it work, appriciate your help!
Code: [Select]
void setup(){
}  // end setup
void loop(){
case 0:
// code for D2
case 1:
// code for D3
//etc
case 14:
//code for  D16
     } // end switch
} // end void loop
