Topic: Windows/Linux/Mac Eclipse plugin to compile and upload arduino sketches (Read 432224 times) previous topic - next topic
BitSeeker
Yes, there is some confusion on my part here.
Eclipse came as standard with the option right there on the welcome page. When I selected to create a C/C++ project I have the option to create an Arduino C++ sketch. This is before any plugins are installed. I am therefore given the impression that I can work with Arduino sketches right 'out of the box'.
When I created a new project I was immediately offered the option to download a better editor and Sloeber came up as a plugin suggestion so I installed that as well. So is Sloeber neccessary, or can Arduino sketches be created without it?
Checking further, I see that Eclipse C++ IDE for Arduino 3.0 is listed as a plugin. I presume that must have come as standard or I might have selected Arduino during the install process. The author is apparently Eclipse CDT, EPL. No mention of any kind of Dog. On further examining the 'more info' link I discovered another video link which took me to a video by Neon. This was actually helpful (no distressing images of a cat being threatened with a large knife!) and showed me how to create a new Arduino project and set up a board. I finally managed to set up a Hello World project on my Uno board.
So its seems that maybe the Sloeber plugin is not required. However, to be fair, I would like to give both plugins a try. However, from the two options in the Eclipse marketplace, which one do I choose to install:
1. The Arduino Eclipse IDE named Sloeber (Product) V4, by jantje and others, EPL  (13.0k)
2. The Arduino Eclipse plugin named Sloeber V4, by jantje and others, EPL  (44.7k)
If someone could confirm the correct plugin, then I will install it and then try the instructions in the link above.
Juraj
1. is IDE bundled with plugin
hichhiker
For what its worth - I never had good luck using the plugin version of Sloeber. In theory it is same thing, but in practice it was a mess. But the "product bundle" version - i.e. single download that contained both Eclipse and all basic plugins you need - worked wonderfully. I highly recommend using that and not worrying about manually configuring it until you are super comfortable with both Eclipse and Sloeber plugin.
-HH
P.S. Get product here: http://eclipse.baeyens.it/stable.php
Thotanos
While not directly having to do with the program, I still have a question regarding the download website:
When I try to download the stable bundle from http://eclipse.baeyens.it/stable.php, my average download speed is about 4.7kB per seconds, so it would need about 7 hours or so. All of this while other downloads are working just fine.
Is this a problem on the server side or one mine?
Is there any other place where I can get the stable bundle?
Jantje
After a DDOS attack I was forced to remove all the download files from my server.
So now all the files are downloaded from github
https://github.com/Sloeber/arduino-eclipse-plugin/releases
If it is slow for you; should speak to github.
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
jschw
Anyone here who got Sloeber correctly working under macOS Catalina 10.15?
Alf_Muc
Hi everybody,
I got it running - almost.
It's a huge Project, initially rised in Arduino (IDE) and now transfered to Windows-Sloeber.
Issues I have:
- the sloeber.ino.cpp is recreated automaticly
   -> this may be ok for small Projects but for my huge Project the automatic creation is faulty
       Some functions are not listed
       Some faulty entries
Does anybody know how to switch off the automatic creation of the sloeber.ino.cpp ???
In Arduino IDE I get the size of used dynamic Memory.
--> Globale Variablen verwenden 1534 Bytes (74%) des dynamischen Speichers, 514 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
How can I get this from Eclipse / Sloeber after compilation?
Jantje
rename you .ino files to .cpp files
Arduino does post processing of the build output which is not done in sloeber.
Jantje
The way I would tackle this
Rename sloeber.ino.cpp to <my project name>.h
In  <my project name>.h delete the section where the .ino files are included and the comment it is auto generated
add #include <my project name>.h to you .ino files
rename you.ino files to .cpp files
Check in your stuff in version control and check  <my project name>.h is there (sloeber.ino.cpp is tagged as a generated file; I am not sure what your version control plugin will do)
Depending on how compliant your code is with C/C++ best practises you are done or need to  do some more work.
hichhiker
Like many people already said, ino format is for beginners who do not really understand cpp and want to get going fast(its basically .cpp and .h combined into one file), or for tiny projects. If you have a significant size project, just switch to using proper cpp files with headers and avoid .ino altogether.
Juraj
I like the forward declarations generation and I know how to avoid  in ino what the sloeber.ino.cpp generator (or Arduino builder) can't handle.
my main Arduino project has 22 ino files. I decided to go the multiple ino code separation way with almost no encapsulation of partial functionality. I could encapsulate functionality into classes with declarations in h files, but it would be only more work
hichhiker
I suppose that is fair. If you are super comfortable with specific quirks of ino sketch preprocessor, it can work, and in the end it is not that far from proper CPP, but I found once I scaled up (I had a project that needed a lot of optimization just to fit on a 2560) I was spending way too much time worried about what my code would actually look after preprocessor re-writes it as CPP and running into all sorts of sketch weirdness and inflexibilities. For me going straight to CPP format allowed for much better control and organization with folders and what not, and allowed me to select what was part of a build and what was not, not to mention much more universal, easier to find resources to help me code that are not specific to Arduino and leaving the door open to compiling using non-Arduino wrapped compilers and making my code more portable to other platforms. But that said, at the time I was working on a very large project, probably larger than belonged on an Arduino, and to this day, I would use ino sketches for small, "blinky-light" type projects.
-HH
