6v6gt:
OK. I'm very impressed by Sloeber / Eclipse, I will use it for new projects which use a supported board, and will migrate old code from the Arduino IDE as and when needed. In fact, I would have benefited from using it much earlier. Karma++ for that.I recently downloaded the released version of 4.2 and it appears to have the bug #907 (miserably slow upload to board speed) which I can work around by copying the call to esptool.exe and executing it manually in a command window. I guess the bug is fixed in the current "Nightly Build", however I'm a bit nervous of using these because here is not much information visible about what has changed. Is a new release planned in the near future ?
Thanks for the nice words
You can see the changes from the arduino menu in Sloeber "do I need to upgrade".
I'm planning to release 4.3 shortly so the nightly is stable at this point in time.
Best regards
Jantje
