I installed, on a windows 10 machine, the windows version 4.3.3 of Sloeber 64-bit bundle as recommended and made sure paths are short and pathnames do not have spaces etc. When I execute Sloeber-ide the first time it shows some errors along with the message that "Failed to configer Sloeber". Here are the errors copied from the Error Log. I repeated the install on a mac and got a similar error message. Is this something I can ignore? I am a beginner at this. I have previously attempted to install the Sloeber plugin on Yakindu SCT and got the same error; that is why I attempted to install using the method recommended in the Baeyens website.
eclipse.buildId=unknown
java.version=1.8.0_131
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -perspective io.sloeber.application.perspective
Command-line arguments: -os win32 -ws win32 -arch x86_64 -perspective io.sloeber.application.perspective
io.sloeber.core
Error
Tue Nov 17 07:45:39 PST 2020
io.sloeber.core
Error
Failed to install [DEPRECATED] Arduino mbed-enabled Boards
io.sloeber.core
Error
Failed to download "
http://downloads.arduino.cc/cores/ArduinoCore-mbed-nonexistant.tar.bz2".
java.io.IOException: Failed to download url
http://downloads.arduino.cc/cores/ArduinoCore-mbed-nonexistant.tar.bz2 error code is: 404
at io.sloeber.core.api.PackageManager.myCopy(PackageManager.java:778)
at io.sloeber.core.api.PackageManager.myCopy(PackageManager.java:740)
at io.sloeber.core.managers.InternalPackageManager.downloadAndInstall(InternalPackageManager.java:351)
at io.sloeber.core.managers.InternalPackageManager.downloadAndInstall(InternalPackageManager.java:130)
at io.sloeber.core.managers.InternalPackageManager.startup_Pluging(InternalPackageManager.java:101)
at io.sloeber.core.Activator$2.run(Activator.java:247)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
io.sloeber.core
Warning
http://downloads.arduino.cc/cores/ArduinoCore-mbed-nonexistant.tar.bz2java.io.IOException: Failed to download url
io.sloeber.core
Warning
org.eclipse.egit.ui
Warning
Tue Nov 17 07:44:52 PST 2020
Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\vicen'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
