Topic: Bootloader 3.3v 8MHz (Read 12235 times) previous topic - next topic
johnwasser
I tried this again last night with no luck, I decided to try and upload the sketch directly with the avrisp I changed the preferences file to upload using avrispmkii but when I tried to burn the sketh the IDE was still expecting a serial port.
Do I need to modify anything else to make that work?  still stumped as to why I can't upload sketches with ftdi, the only thing I wonder is if the 8Mhz resonator that I am using is not up to the job.
Did you shut down the Arduino software before making the change and then re-starting?  I think Arduino generally reads the preference.txt and boards.txt files only at startup and writes them (at least preferences.txt) back on shut-down.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
markab
Hi, yes, I shutdown before.
Basically when I set the upload using avrispmkii and then hit the sketch upload button it asks me to select a serial port like when uploading via ftdi usb.  However when I burn a boot loader with the programmer it just goes ahead and does it no questions asked.
rodrigorrm
#17
Mar 24, 2017, 06:59 pm Last Edit: Mar 24, 2017, 07:12 pm by rodrigorrm Reason: Just added a picture of the assembly for bootloader burning
Hello guys,
I'm having a hard time putting together a breadboard Arduino @ internal 8MHz clock and 3.3V power.
I used the instruction laid as in: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard.
The resulting arduino worked just fine @ 5V. I managed to burn the bootloader indicated for internal clock and also managed to upload my application.
However, it just does not run when I switch power to 3.3V.
Just in case I attached a picture of my setup for burning the MCU.
What am I doing wrong?
Thank you,
Rodrigo
CrossRoads
"What am I doing wrong?"
Picture didn't make it. Reply, and scroll down to Attachments and other options, browse to your file.
"it just does not run "
So what does it do? When you burned the bootloader, did you select a board type that used the internal 8 MHz oscillator?
This IDE add-in makes it easy to set different options for speed, clock, brown out detection (reset when power voltage gets too low), etc.
https://github.com/MCUdude/MiniCore
