Topic: (ASK) RFID on Arduino (Read 5221 times) previous topic - next topic
mafa
Nov 26, 2011, 12:53 pm Last Edit: Nov 26, 2011, 01:00 pm by mafa Reason: 1
Hi All,
Is there anybody knows about how to connect RFID with arduino? what kind of RFID can read until 5 meters and can works with my arduino?
Thanks before
robtillaart
MOst RFID reades have a standard serial output that can be connected to Arduino (optionally convert voltages from 12 - TTL level - be careful)
Check - SParkfun.com for examples
5 Meters is quite a distance imho.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Grumpy_Mike
5 meters is impossible with a standard RFID, I am not even sure you can do it with a UHF system and these are very expensive.
In fact I don't think you can do it with an active tag either, although this would give you the maximum range.
mafa
thanks for your info
oh, so my project is impossible?
Grumpy_Mike
Well you haven't said what your project is it is hard to say. But if it requires a 5 meter range then sorry no.
tkbyd
To get an Arduino to "see" something 5m away, DCDWireless would be good...
http://DCDWireless.com
We're getting closer to releasing the units out into the wild. Not there yet, but getting closer.
Or, you could put something together using the same RF modules.
Forget for a moment HOW you are going to do "it"... Tell us WHAT do you want "it" to do?
maniacbug
You can see here for one example: 125Khz RFID Module RDM630.  I've never heard of 5m for RFID, though.
mafa
ok. thanks for sharing Guys
