Topic: How to obtain the remote client IP address when using the Ethernet Shield (Read 26284 times) previous topic - next topic
Philgaskin
This had baffled me for some time. There are many examples of how to do this in previous versions of the ID; however none appeared to work with v1.0 - so I thought I'd share my workaround.
I wanted to record the remote IP address of clients using my Arduino as a web server.
To make it work, I did the following:
I added the following lines to the end of the EthernetClient.cpp file:
uint8_t *EthernetClient::getRemoteIP(uint8_t remoteIP[])
  W5100.readSnDIPR(_sock, remoteIP);
  return remoteIP;
I then added the following line (under the virtual void stop(); line)to the EthernetClient.h file:
uint8_t *getRemoteIP(uint8_t RemoteIP[]);//adds remote ip address
Finally I used the following code in my sketch to access the remote IP:
client.getRemoteIP(rip); // where rip is defined as byte rip[] = {0,0,0,0 };
to display the IP in the serial monitor, I used:
for (int bcount= 0; bcount < 4; bcount++)
        Serial.print(rip[bcount], DEC);
        if (bcount<3) Serial.print(".");
I'm not sure that this is the most elegant way, but it works in the IDE v1.0
zoomkat
I tried your example, but the "rip" in the below arduino code needs to be declared some where per the compiler. Where/how is this done?
Philgaskin
Zoomcat, it's in the comments of the sketch code.
Basically you need to define rip as a byte array:
either byte rip[] = {0,0,0,0 }; which assigns it as 0.0.0.0 by default or byte rip[4]; which defines it as null before use.
zoomkat
Adding to some server code I already have below, I just get 0.0.0.0 printed to the serial monitor. Bottom is where your code is pasted in the .ccp and .h files. Such is the world of copy/paste. This is with the 1.0 IDE.
//zoomkat 12-8-11
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte rip[4];
//byte rip[] = {0,0,0,0};
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(4, OUTPUT); //pin selected to control
  //start Ethernet
  server.begin();
  //enable serial data print
  Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
Serial.println();
          //now output HTML data header
             if(readString.indexOf('?') >=0) { //don't send new page
               client.println("HTTP/1.1 204 Zoomkat");
               client.println();
               client.println();
             else {
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>");
          client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
          //client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">");
          client.println("<IFRAME name=inlineframe style=\"display:none\" >");
          client.println("</IFRAME>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            digitalWrite(4, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(4, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
  virtual void flush();
  virtual uint8_t connected();
  virtual operator bool();
// the next function allows us to use the client returned by
// EthernetServer::available() as the condition in an if-statement.
EthernetClient::operator bool() {
  return _sock != MAX_SOCK_NUM;
return remoteIP;
Philgaskin
Zoomcat,
You've not put the client.getRemoteIP(rip); line in to actually read the remote IP prior to printing it.
client.getRemoteIP(rip); // this is the code that actually puts the IP into the variable rip
        if (bcount<3) Serial.print("."); else Serial.println();
samlro2
I am a super newbee. I am not sure where to connected the ethernet cable if I want to get remote data from home. The router?
zoomkat
Added the client.getRemoteIP(rip); line, and voila!, it works.
Targettio
samlro2, your question isn't directly related to this topic, but I will help you out.
If you want to connect to your Arduino via a network or internet you will need to plug it into a router.
Then, from within the network, you can access the arduino simply by entering the arduino's IP into a browser (the IP you set within the sketch).
Connecting via the internet, things get a little more complicated:
* First you will need to set up your router so it routes all port 80 requests to the arduino. google port forwarding and your router model.
* Second you will need some way of contacting your router from the internet, your external IP address is likely to vary, so the best way is to get a domain name. google about dynamic domain name providers (i.e. dyndns, no-ip etc).
There are a few guides that go into a lot more detail and give full sketches. Google should be able to help there.
grossman
I spend a lot of time to find a solution of error
no matching function for call to 'EthernetClient::getRemoteIP(byte* [4])'
The right way is to replace the line of code
byte *rip[4];
with
uint8_t rip[4];
Really thanks for the new Ethernet library, but why is the example wrong?
So there is an error on the 164 line in file EthernetClient.cpp too, the line must be
uint8_t *EthernetClient::getRemoteIP(uint8_t *remoteIP)
Could this solve your problem?
zoomkat
Discussion that might be of interest.
http://forum.arduino.cc/index.php/topic,82416.0.html
karlok
Even if this discussion is old, it is still relevant.
Improvement:
EthernetClient.cpp
IPAddress EthernetClient::getRemoteIP()
  byte rip[4];
  W5100.readSnDIPR(_sock, rip);
  return rip;
EthernetClient.h
IPAddress getRemoteIP(); // get Remote IP address
Reason:
You don't need to use some pass by reference and use return combined, that is redundant.
Here you just use return value.
Example:
  if (client)
    Serial.println("new client");
    IPAddress remoteip = client.getRemoteIP();
Serial.print("IP: ");
    Serial.println(remoteip);
    client.stop();
Regards.
giampiero7
@karlok returning a pointer declared in the local scope of a function is not the right thing to do.
The "pass by reference" method is the right one.
SurferTim
@karlok returning a variable declared in the local scope of a function is not the right thing to do.
+1
AWOL
Or you could qualify the local "rip" as "static".
This isn't ideal either, though.
hilltop
Why is this code not incorporated into the Ethernet library?  It's very short but quite helpful!
