Topic: Programmer is not responding problem after attempting to bootload atmega 328 (Read 1 time) previous topic - next topic
tnflyboy
I recently attempted to load the arduino bootloader on to an atmega328 chip that I recently purchased, following these instructions:
http://arduino.cc/en/Tutorial/ArduinoToBreadboard
After completing the instructions, my Uno would no longer work properly and the chip that I attempted to bootload would not work either. Every time I attempted to load a sketch on to the Uno I got the following message:
Code: [Select]
I have performed the suggested troubleshooting steps on the arduino guide page and performed the loop-back test (it worked). Here are my specs:
  • Your operating system.
    Mac OSX 10.7.2
  • What kind of board you have.
    Arduino Uno
  • Whether or not you were ever able to upload to the board. If so, what were you doing with the board before / when it stopped working, and what software have you recently added or removed from your computer?
    Yes, I have been able to upload to the board previously. For other comments, see above.
  • The messages displayed when you try to upload with verbose output enabled. To do this, hold down the shift key while clicking on the upload button in the toolbar.
    See code above
Bp103
You could maybe try the Parallel Programmer then burn the bootloader onto the chip while its still in the arduino.
http://arduino.cc/en/Hacking/ParallelProgrammer
I don't know much about mac but this is what i used to make avrdude write the bootloader to it. (The ide failed to do it for some reason)
Its a bat file for windows but I think you'll get it.
Code: [Select]
set bootloader=C:\arduino-1.0\hardware\arduino\bootloaders\optiboot\optiboot_atmega328-Mini.hex
rem   Bootloader path
set avrdude_path=C:\arduino-1.0\hardware/tools/avr/bin/
rem   Path to avrdude
set avrdude_conf=C:\arduino-1.0\hardware/tools/avr/etc/avrdude.conf
rem   path to avrdude.conf
%avrdude_path%avrdude -C%avrdude_conf% -v -v -v -v -patmega328p -cdapa -F -Uflash:w:%bootloader%:i
btw everything encased in %'s are strings replace them as needed.
tnflyboy
Bp thanks for the info, I unfortunately don't have a parallel connector or a port on my computer. I think it'd probably be easier for me to buy another 328 with the bootloader already on it.
Jim, I don't have the auto-reset still disabled.
More info... Here's what comes up when I try to upload Blink to the board.
Code: [Select]
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/tnflyboy/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbmodem411
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: ser_recv(): programmer is not responding
avrdude done.  Thank you.
Any other ideas from anyone? I can't really be the first person with this problem.  :)
smeezekitty
USB to parallel adapters are fairly cheap and then you would have it for the future.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
tnflyboy
update:
I replaced the atmega328 on my uno with an atmega328 chip with bootloader already installed on it from sparkfun. Attempting to upload the blink program to the board produces the same error. Is my uno shot, or is there anything else I can do?
tnflyboy
Ok, it's working now. Rather than delete this post because I realized I'm an idiot, I'll keep it up, just in case someone has a similar problem... Turns out the chip was put in backwards. Again, I'm an idiot.
CrossRoads
tnflyboy
Didn't really notice, I was never able to get a program loaded for obvious reasons, so I didn't keep it running too long.
