Topic: ATTiny 25/45/85/2313 Pin numbers (Read 29962 times) previous topic - next topic
balam
I  guess the analog is the PB0/AIN0/D9
That is one of the two inputs to the analog comparator.
sensVal = analogRead(sensPin); // READS sensor,
If you are using this core...
http://code.google.com/p/arduino-tiny/
...zero is always returned.
Thank you.
yes  I am using  this cores
you mean that analog input does not work?
on the   core pin s file
seems like there is analog port  as  PIN_A0  (3)
been trying to read a sensor and turn an led but doe snot work
any help is really apreciated ,  how can I read a sensor   from this  2313 chip.
thanks
Coding Badly
The processor does not have an analog-to-digital converter (ADC).  So, yes, analog input does not work.
Two things come to mind...
1. Add an external ADC.
2. Atmel has a whitepaper describing how to mimic an ADC using the analog comparator.  It requires some external components (I think two).  If you're interested, I'll try to find a link.
balam
THANK  you.
I been  editing the  core pins
but now that you are saying that analog input is not supported
yea I will be interested in find out how to add a sensor
funkyguy4000
Accelerate to 88 miles per hour.
Coding Badly
Why are you bumping this topic?
Arduino_User49502
smeezekitty, do you assign thepins by the PB# or just # in the code.
DrAzzy
You use the numbers to refer to the pins in your code
Please don't bump three-year-old threads.
ATTinyCore and megaTinyCore for all ATtiny, DxCore for DA/DB-series! github.com/SpenceKonde
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
