Topic: problem programming Attiny85 with UNO (Read 31029 times) previous topic - next topic
ProfePaco
Hi:
I am following these instructions to program Attiny85:
http://hlt.media.mit.edu/?p=1229
First of all, I have realized that we cannot use arduino IDE 1.0. So I downloaded version 0022. There are no compiling errors in this version.
However, as I try to upload the simple blink example, moving the output to pin 2, I obtain these results:
Problem uploading to board:
Binary sketch size: 658 bytes (of a 8192 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I am doing exactly the same steps and connections as that webpage states... what is wrong?
Thanks in advance
Coding Badly
Did you disable auto-reset using a 10 uF capacitor?
ProfePaco
Yes, following exactly those instructions.
Coding Badly
The error indicates that either the Arduino ISP sketch is not installed or that auto-reset is still firing.  I suggest working through the steps a second time.
guardian_of_light
http://hlt.media.mit.edu/?p=1695 Updated for UNO and 1.0 IDE. Works well, I have tested it. Of course, Coding_Badly's response still applies, but also make sure everything is wired and powered correctly. I spent an hour messing with the IDE files only to realize my reset resistor was connected to GND.  :smiley-red:
ProfePaco
Thanks a lot.
I am taking breakfast now, no time to check it.
This afternoon I will try it.
ProfePaco
Please, help me.  =( =( =(
I cannot find anything wrong. Follows some pictures with all the info.
I have changed the capacitor as well, just to check whether it was defective.
any feedback? Thanks.
ProfePaco
And I have tried to burn the bootloader to run at 8MHz, and I obtain the same error:
ProfePaco
More trials...
I am not sure whether I have to use a capacitor or a resistor to disable the autoreset. So now I have used a 150 Ohm resistor (not have 120) between Reset and Ground. Is this another option? is this right?
Anyway, I obtain the same error as before. This is really frustrating....
ProfePaco
Now I tried reset-resistor-+5V... same error...
Coding Badly
The wiring looks fine.
You may not have to use either.  The latest Optiboot does not require disabling auto-reset.  If you purchased the Uno recently, it may already have a "good" bootloader installed.  Try...
  • Removing the capacitor and / resistor
  • Re-uploading the ArduinoISP sketch (don't forget to change the board selection to Uno)
  • Uploading a test to the ATtiny
    http://www.arduino.cc/playground/Main/DisablingAutoResetOnSerialConnection
    Don't go below 110 ohms or above 124 ohms
    Do you have another Arduino board?
ProfePaco
#11
Dec 21, 2011, 11:43 pm Last Edit: Dec 21, 2011, 11:45 pm by ProfePaco Reason: 1
I have a nano as well, can I use it?
removing capacitor or resistor does not help....
ProfePaco
#12
Dec 21, 2011, 11:55 pm Last Edit: Dec 21, 2011, 11:57 pm by ProfePaco Reason: 1
so this is what I have done:
I load file/examples/ArduinoISP
I set board = Arduino Uno
I upload it
No errors
Then I load Blink example.
board = Attiny internal 1MHz
Programmer = Arduino as ISP (and this was selected before, for the previous case as well)
I upload it
I get this error:
Binary sketch size: 768 bytes (of a 8192 byte maximum)
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x64
avrdude: stk500_cmd(): programmer is out of sync
in the last case, if the capacitor is used. the error is:
Coding Badly
It should work well.  I suggest using the 120 ohm resistor method to disable auto-reset.  You will have to find a combination of resistors to get the value in the correct range.  I don't know if using a capacitor is appropriate with the FTDI chip.
If you get the Nano working as an ISP, I also suggest updating the Uno bootloader.  Not having to fiddle with auto-reset is very nice!
Unfortunately, you are not the first person to have trouble disable auto-reset on an Uno.  You may want to search through the forum for other suggestions.
And just to make certain you are not wasting your time with the Nano... Whenever you get the "expect=0x14, resp=0x51" error or the "not in sync: resp=0x00", you have to re-upload the Arduino ISP sketch.  There is a very good chance the sketch was erased when the bootloader ran.  If you have not been re-uploading the Arduino ISP sketch when that error occurred, this would be a good time to start from scratch using the capacitor to disable auto-reset.
Coding Badly
I upload it
No errors
Did you disable auto-reset at this point?
These can be ignored.
Huh.  That's different.
