I (think I) have been able to bootload the chip on breadboard using Uno and these instructions:
Used ArduinoISP from Arduino-0022 due to the bug with bootloading, otherwise using 1.0 (and bootloaded using that aswell).
But I am unable to upload sketches. If I select "ATmega328 on a breadboard (8 MHz internal clock)" and try to compile, I get
In file included from C:\Users\asdf\Desktop\arduino-1.0\libraries\OneWire/OneWire.h:7,
from Fan_PWM_PID.cpp:2:
C:\Users\asdf\Desktop\arduino-1.0\hardware\arduino\cores\arduino/Arduino.h:212:26: error: pins_arduino.h: No such file or directory
On the other hand, if I select Uno I get
"avrdude: stk500_getsync(): not in sync: resp=0x00"
Is this breadboard profile only for bootloading or am I missing the include file?
The .zip file in that tutorial is outdated! Don't use it with 1.0
Take the standard boards.txt file of your IDE and modify/add one entry to your needs.
To get the fuses right, please use the online fuse calculators for AVR (see my signature). It is rather easy to use. It works both ways. Either set the fuses and get the hex-values you need, or enter hex-values and see what they mean.
OK, but shouldnt the fuses in the boards.txt be correct atleast?
It has now Low 0xE2, High 0xDA and Extended 0x05.
Seems the extended flags control only brown-out detection, and if I enter 0x05 the the calculator I get BODLEVEL1, 2.7 V. But selecting the same setting in calculator gives 0xFD, it varies between 0xFF and 0xFC.
If you can upload the "ArduinoISP" sketch to your Arduino board, it should work.
A blank (fresh from factory) ATmega168/328 chip will work with just 5V and GND. Don't forget a small capacitor (4.7µF or so for starters) between 5V and GND.
Depending on the FUSE settings you program, this may change and it may need an external crystal / resonator. These things are only a couple of cents, best to have at least one just in case.
