Topic: Acrylic arduino case... (Read 9268 times) previous topic - next topic
mowcius
Sep 27, 2009, 12:32 pm Last Edit: Sep 27, 2009, 12:33 pm by mowcius Reason: 1
I am thinking of doing a small run of acrylic arduino covers. This will not be a full case but instead could provide a base and 'lid' for an arduino stack. The parts will be done in laser cut 3mm acrylic similar looking to:
but they will be cut to the exact size of the arduino base...
These parts will be done in various colours and can be modified to include engraved text, pictures etc...
I will also be doing a small run of arduino shield seperators, these will be very similar to the bases but will have cutouts for the pin headers. They will stop any connections from one board shorting on another board. They may also be done on 0.5mm laminated ply for shields that do not have pin headers long enough for a 3mm board in the middle.
As a first production run these will be very cheap, price not decided yet, but not much more than the postage...
Post here if interested...
Mowcius
Easty
I'm interested in the base/lid idea! Keep us postred on your progress.
magicmike
Good idea. I created a small run of cases out of acrylic, which I think worked very well. The problem with having a screw down full case as a small run is cost (I would have to sell it for about $16). If you are not covering it for protection, a flat mounting panel may be the way to go.
The image below shows the case before it is drilled for power/sensors etc.
mowcius
I did think of a full case but there are loads of those available already and it would be more expensive.
I've done the designs now and I'll try and get some cut this coming week...
Mowcius
florinc
If functionality is preferred over beauty, one can use this case from Staples, about US$3:
More photos here:
http://www.flickr.com/photos/11567579@N05/3861093722/
Easty
Quote
Happy to help test your first run!  ;)
mowcius
Quote
Yes, there are those and many others but this is not a case, rather a 'bottom and top' (and seperators) and they will be less than $3 because acrylic is pretty cheap and so's electricity...
Quote
 8-) There's not exactly a lot of testing to be done but I may be feeling nice... :D
Mowcius
mowcius
The first 4 acrylic pieces are hot off the laser cutter... Literally :D
Shiny clear bits...
I will post some pictures later once I have got a bit more time to cut the other parts and some more of the base/lid combo...
I am also cutting some 3mm acrylic washers out of the little bits that can't be used for anything...
These will obviously look good with the base/lid and let you space them away from your boards...
Mowcius
mowcius
Here are some pictures of the first (second) design:
http://www.flickr.com/photos/mowcius/sets/72157622349824171/
If anyone would like to buy some then just send me a PM and I will sort it out... I could also customise them or do them in different colours if wanted...
I also have 4 of them that were done slightly wrong on one of the corners so are going on the cheap (see the set for details)... If someone wants one then just send a PM and you can have one for price of p & p...
Mowcius
Jassper
Nice, but I suggest rubber feet. The screws will slide around on hard serfaces.
mowcius
Quote
Yes, that's a good idea... The screws that were on were just some I had lying around and not the ones I will be using permenantly... I haven't sorted out mounting screws yet...
Can anyone suggest screws with small rubber ends or something because I'd like them built into/onto the screws rather than been glued on...
Mowcius
mowcius
Osgeld
check your local home store, they sell caps that are attached to a loop, so you can run a screw trough it then snap the cap on top
alternatively piano bumpers, they do not glue on but rather get shoved into a hole, and I might know where to get some (actually i just received about 85lbs of them today)
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
mowcius
Hmm, I will try and have a look around. So far I have not had any trouble with the arduino moving as it's normally constrained by wires...
Mowcius
Tchnclfl
Quote
Good Lord...For what? :O
