Topic: Arduino 1.0 -> Serial.print NOT asynchronous? (Read 9925 times) previous topic - next topic
wipo
Jan 02, 2012, 09:52 am Last Edit: Jan 02, 2012, 08:12 pm by Coding Badly Reason: 1
first of al, english is not my first nor my second language so I'll try to do my best.
In the past  few months I worked with the arduino 0022 software. Yesterday I finaly downloaded the new Arduino 1.0 software, where I found some interesting new feature in the serial.print function:
arduino reference page: "As of version 1.0, serial transmission is asynchronous; Serial.print() will return before any characters are transmitted."
So I made a little sketch to test this.
Code: [Select]
void loop() //Main Loop
 timebegin = millis();   //take the time before sending data
 Serial.print("lkjljlkjlkjljlkjlkjlkjlkjlkjlkjlkj");   // some random text, not important
 timeend = millis(); //take the time afte sending data
 Serial.print(timeend);
 Serial.print(",");
 Serial.println(timeend);
 delay(100); //wait some time before doing this loop again.
If I do timeend - timebegin. I get a value of 5ms. So the serial.print function took 5ms before returning. I compiled this sketch with arduino 0022 and arduino 1.0. There is no difference in time so where is the asynchronous ???
So if in arduino 1.0 the Serial.print() really would return before any characters are transmitted, why does It take 5ms to return and why is there no difference in time with the arduino 0022 version?
Moderator edit: [code] [/code] tags added.
PaulS
Quote
Since you didn't show setup, where Serial.begin() sets the speed, it's impossible for anyone else to replicate your test.
At reasonable baud rates, millis() is not particularly good as a timer. It's like using a calendar to time how long it takes your wife to get ready to go somewhere. Makes you feel like you are doing something, but that's about all.
Try using micros(), instead. Also, post ALL of your code.
wipo
#3
Jan 02, 2012, 11:17 am Last Edit: Jan 02, 2012, 08:14 pm by Coding Badly Reason: 1
Ok here it goes
its an atmega328 8mhz board.
changed code to
Code: [Select]
unsigned long timebegin;
unsigned long timeend;
 Serial.begin(57600);
 timebegin = micros();
 timeend = micros();
 Serial.println(timeend-timebegin);
 delay(100);
output in arduino serial monitor for 0022
Code: [Select]
5472
5464
5472
5472
5472
5472
5472
output in arduino serial monitor for 1.0
Code: [Select]
2208
2208
2208
2208
2208
2208
Ok, now I see some difference. But still 2ms is a long time for just filling a streambuffer  that will be send assync.
The fact is that I have another lager sketch with serial.print in it and a (fps) loopcounter. Logically I should, with the 1.0 version compared to the 0022 version now get more FPS/Counts in this sketch. But I don't :s
wipo
#4
Jan 02, 2012, 12:53 pm Last Edit: Jan 02, 2012, 08:15 pm by Coding Badly Reason: 1
whow again I did find a strange behaviour with this new serial.print().
Take the sketch in prevouis post change baudrate to 19200 and you get this output in arduino 1.0
Code: [Select]
1832
1832
1824
1832
1832
1808
1824
1824
1832
So the time spend for serial.print() for sending the same string is less when decreasing baudrate. Increase the baudrate and the time spend by serial.print() will be larger. :s  Can some explain this? :)
graynomad
Baud rate should have no affect on this until the buffer fills up at which time you will see delays.
Is the data displayed starting at the absolute first printing, or after some time?
I would just do this once in setup and get the timing from that.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Coding Badly
#6
Jan 02, 2012, 08:48 pm Last Edit: Jan 02, 2012, 08:49 pm by Coding Badly Reason: 1
I cannot reproduce your test results.
The test...
Code: [Select]
static char S[] = "123456789.123456789.123456789.123456789.123456789.123456789.123456789.123456789.123456789.123456789.";
static unsigned short D[sizeof(S)];
 char* R;
 unsigned short* P;
 R = &S[0];
 P = &D[0];
 while ( *R != 0 )
   Serial.write( *R );
   timeend = micros();
   *P = timeend - timebegin;
   ++R;
   ++P;
 R = &S[0];
 P = &D[0];
 while ( *R != 0 )
   Serial.println( *P );
   ++R;
   ++P;
 Serial.flush();
 delay( 5000 );
The results...
Code: [Select]
52  <-- ISR fires sending the first byte
44  <-- ISR fires sending the second byte
28  <-- third byte buffered
24
24
48  <-- ISR fires sending the third byte
24
24
24
28
44
28
24
28
24
48
24
24
24
24
48
24
28
24
28
44
28
32
24
24
48
24
24
24
28
44
28
24
28
24
48
24
24
24
24
48
24
28
24
28
44
28
24
24
24
44
24
32
24
28
44
28
24
28
24
48
24
24
24
24
48
24
28
24
28
44
28
24
24
24
48
164  <-- buffer full; write blocks
164
168
164
168
164
168
164
168
164
168
164
168
164
168
164
168
164
168
52
48
24
24
24
52
24
24
24
28
44
28
24
28
24
48
24
24
24
24
48
24
28
24
28
44
28
24
24
24
48
24
24
28
24
52
28
24
28
24
48
24
24
24
24
48
24
28
24
28
44
28
24
24
24
48
24
24
24
24
48
24
28
24
24
52
24
28
24
24
48
24
24
24
28
44
28
24
28
24
48
156
168
172
160
164
168
164
168
164
160
164
168
164
168
164
168
164
168
164
Looks to me like Serial is working.
fat16lib
#7
Jan 02, 2012, 10:01 pm Last Edit: Jan 03, 2012, 12:22 am by fat16lib Reason: 1
Are you using the latest release of Arduino 1.0?
Are you using a 8 MHz board?
When I run your sketch I get this
Quote
956
952
956
956
956
952
956
952
952
This is still very slow.  I have been working with sixeyes to optimize writing strings to a serial port.  See http://arduino.cc/forum/index.php/topic,85207.0.html.
The problem is that print(const char*)  ends up writing to the buffer a character at a time.  My new serial library is faster but still a bit slow since Print::print(const char*) calls Print::write(const char*) which does character at a time writes.
With my new library I get
Quote
276
276
272
272
272
I have optimized write(const char*) in my new serial library. I will soon post the version with optimized write(const char*).
If I change the print to write with my new library like this:
Code: [Select]
#include <SerialPort.h>
// port zero, 63 byte RX buffer 63 byte TX buffer
SerialPort<0, 63, 63> NewSerial;
#define Serial NewSerial
 Serial.write("lkjljlkjlkjljlkjlkjlkjlkjlkjlkjlkj");
 timeend = micros();
 delay(100);
I get very fast buffering:
Quote
52
56
60
52
64
64
52
wipo
@Coding Badly:
thx for taking the time to do some tests. But you have a complete other sketch. Please try to use my sketch on a 8mhz board like I did. For most beginners, my sketch is more easy to understend. Your sketch does in fact the same but your code is more difficult for most beginners. So if you conclude that your timings are good with your code, then why are my timings bad with my code?
@fat16lib:
Also thx for taking your time to check out my problem. I'll check out your topic and test your code asap.
INFO: I use a atmega328 board running on 8mhz and downloaded the last arduino 1.0 version.
EXTRA: I took the time to compile some other sketches with arduino 1.0 and they are all slower compared to the same sketch compiled with arduino 0022. I do use micros() to compare timings en also use a simple loopcounter. I think I'll stay with arduino 0022 for a while.
graynomad
Coding Badly
Apply this...
http://arduino.cc/forum/index.php/topic,85908.msg643676.html#msg643676
...and please let us know if it makes a difference.
kawoonoon
hi guys..
I just want to clarify,
what communication does Serial.print() do?
is it asynchronous or synchronous?
thank you...
graynomad
