Topic: dtostrf() help (Read 147952 times) previous topic - next topic
PaulS
Quote
The LCD library I'm using won't print floats.
But, you don't want to print floats.
Nick_Pyner
#16
May 26, 2014, 04:16 am Last Edit: May 26, 2014, 04:39 am by Nick_Pyner Reason: 1
The LCD library I'm using won't print floats. I need to pass in a character array.
That is either nonsense, or time to move to a proper library. It is definitely time to be more forthcoming with your code.
If you want to print floats, you should be able to so - without dtostrf().
I have never been able to understand why there has ever been a need for this float to string conversion stuff, or why anybody thinks they need it now. I can only assume it is some nasty legacy from the past when Arduino was incapable of handling floats.
The only time I have ever seen a need for Arduino to feed strings was when a receiving non-Arduino programme demanded it  I'm not aware of any hardware device that demands to be fed with strings.
Another thread is here   http://forum.arduino.cc/index.php?topic=212255.msg1558900#msg1558900
mrthekod
I used dtostrf to pass an integer to a routine I wrote. It requires a char array that I then use chop each letter into vertical stripes to display on an LED cube.
Worked a treat for me. Kept me away from using String.
PaulS
Quote
Why would you use double to string, formatted to deal with an integer?
mrthekod
Because it worked perfectly, I was planning on looking in to other more appropriate options later.
What would you use to tun an int into char array? I'm guessing there is itostrf, I didn't bother checking as this worked, and it was 4am, I was grumpy and I was calling this a win.
odometer
Why? There are other ways, such as the sprintf function.
http://www.cplusplus.com/reference/cstdio/sprintf/
(Tip: Arduino won't let you use sprintf on floats, but integers are OK.)
odometer
#21
Jul 13, 2015, 12:52 pm Last Edit: Jul 13, 2015, 12:52 pm by odometer Reason: correct typo
I might, too, if it were 4 a.m. and I were grumpy.
But for myself, I use sprintf() or else arithmetic. And by arithmetic, I mean use division and modulus to get at the values of the digits, then add '0' (with single quotes) to each digit to convert it to a character.
chupo_cro
#22
Feb 08, 2017, 12:42 am Last Edit: Feb 08, 2017, 12:56 am by chupo_cro Reason: Corrected the link
Because sometimes you have to build the string so you can calculate the length to be able to make a POST request as mentioned in:
http://forum.arduino.cc/index.php?topic=85523.msg641844#msg641844
Chupo_cro
jimLee
Umm, you do realize your answering a question that was asked 2-3 years ago, right?
-jim lee
PNW Ardiuno & Maker club
1012 9Th Street, Anacortes, WA 98221 (Around the back of building)
chupo_cro
Quote from: jimLee Wed Feb 08 2017 04:21:34 GMT+0100 (Central European Standard Time)
-jim lee
Yes I do. Is that a problem? I've found this thread when I was looking for some info about using floats with sprintf() and dtostrf() on avrlibc so there is a chance someone in the future will read this thread to find some useful infromation. I think the purpose of forum posts is (among the others) to be used as a knowledge base.
In fact, I created the account 2 years ago when I noticed a thread which was full of wrong informations (it was something related to millis() if I remember correctly) but then in the and I did not post anything.
Chupo_cro
