Topic: xsm-d1088BRG and shift registers (Read 3383 times) previous topic - next topic
mistermax
Can anyone please confirm if the xsm-d1088BRG 8*8 LED matrix is red green only, or can it handle other/all colours?
I received some as part of a gift at Christmas, and am not sure if they are red/green only.
Also, could someone please point me at an example of how to use the LED matrix using 74HC595 shift registers? I've had a look at the shift registers page here http://www.arduino.cc/en/Tutorial/ShiftOut
I'm interested in using PWM with the matrix to improve the type/range of effects available to me.
many thanks in advance.
evanrich
Welcome to the forums.  Have you heard of a wonderful site called Google?  Behold what it can tell you:   http://www.alibaba.com/product/hk1002352744-118423910-103181892/8_8_DOT_Matrix_LED_Display.html
mistermax
Yes, I'm well aware of Google.
What I'm really after is a tutorial on shiftregisters & LED matrices.
Thanks.
evanrich
#3
Feb 15, 2012, 10:41 pm Last Edit: Feb 15, 2012, 10:43 pm by evanrich Reason: 1
evanrich
btw,  if you need more, I ordered 30 from sure, because they told me they were common cathode units, when in fact they were common anode.   I'll be happy to sell them dirt cheap if you need more.
ArnieNFW
Hi, the datasheet you refer to says this:
Detailed Product Description
dotmatrix display
different size available
Common Cathode(/Common Cathode)
evanrich
dotmatrix display
The link has changed aparently as it was what came up in a google search before.  Regardless, two items to the right was the correct one:
http://www.alibaba.com/product/hk1002352744-122190148-103181892/XSM_D1088BRG.html
The ones that sure electronics sells are common anode, the common cathode modules have an A at the end instead of a B (ARG, instead of BRG)
