Topic: Error compiling. Unable to rename core.a (Read 32428 times) previous topic - next topic
ArchiM
Hi everyone.
I just started trying to make my recently buyed first arduino and I got stuck just in the very first step of making it work.
Trying to upload the blink example but with different time lapses for blinking, i get the next error while trying to compile.
"C:\Program Files\Arduino\arduino-1.0\hardware\tools\avr\bin\avr-ar: unable to rename 'core.a'; reason: File exists"
I'm using an Arduino Uno, with Windows Vista. I've installed it as told in the instructions and the thing is it has worked once of the about 50 that i've tried, and it compiled and uploaded.
I tired to reinstall all the folder, and worked well in the first try, but I keep on getting the same message now. :(
Any ideas!?
Thanks
ArchiM
Atticus12
Have the same problem. Tried giving the folder permissions to make changes but nothing works. Please someone help me.
clvrmnky
Hi everyone.
Any ideas!?
Thanks
You probably have some real-time anti-virus program running. You should disable this, or make sure everything to do with AVR development is ignored by it.
I yield() for co-routines.
smeezekitty
Ignore it. I have had there error several times and for me, it always uploads if I ignore it and wait a few more minutes.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
Louis Davis
I would suggest moving the Arduino folder outside of "Program Files".
This is the convention that I follow and I have not had any problems:
C:\arduino\arduino-1.0
C:\arduino\arduino-1.0.1
Staannlley
Hey guys, this stupid problem also happened to me.
Just turn off your antivirus system, and it should be fine.
lalitsharmaku
Thanks for all those who mentioned to disable antivirus, it works.
dorciley
ola estou com esse problema ja desativei anti vírus mas o erro continua o mesmo eu uso windows 8.1 64bits
jonasfs
Estava com esse mesmo erro.
Encontrei a solução em um fórum que dizia:
"(...) tem que apagar essas pastas aqui:
No Mac OS X:
/Users/(username)/Library/Arduino15
No Windows:
C:\Users\(username)\AppData\Roaming\Arduino15
C:\Users\(username)\AppData\Local\Arduino15
No Linux:
/home/(username)/.arduino15    (a.k.a. ~/.arduino15) "
Seque o link do fórum: https://www.robocore.net/modules.php?name=Forums&file=viewtopic&t=5232
benhamouda
Hello,
I had the same problem, just run Arduino as an administrator (on Windows).
Good luck.
Arnough
Moving the folder as stated worked for me. Thanks so much.
Xukyo
I had the same issue installing the IDE on a new PC.
I had to change Tools -> Programmer to "Arduino as ISP"
Arnough
This solution works only temporarily.
Same error appeared the next day. Moving again to another path made error disappear.
barsznica
Lights, music, electronics, Action!
