Topic: ATtiny84 and TinyDebugSerial shows garbled text.... (Read 6896 times) previous topic - next topic
wanderson
He used the same pin as used if a xtal is hooked up to the chip for slower speeds, and since faster speeds need a crystal in most of the tiny's he had to switch the pin for those speeds.  If you wanted to change the core code provided in the tiny libraries you could make any pin the default serial output.
