Topic: SRAM and storing strings (Read 13064 times) previous topic - next topic
baum
My current project has a lot of variables and a lot of strings, and I don't want it to crash due to a lack of RAM. I though that I could wrap strings in F() to save space, but then I get
Code: [Select]
warning: only initialized variables can be placed into program memory area
What's this about?
Also, will the compiler/AVRdude tell me if I have too many variables and am going to use up the RAM?
Thanks,
baum
dxw00d
Quote
Only under certain circumstances. As I can't see your code, I can't tell what you're doing wrong.
Quote
I don't think so.
PaulS
Quote
What's this about?
I think that the message is pretty explicit. Flash/PROGMEM is read-only at run time, so placing an uninitialized variable in Flash/PROGMEM means that it can never be assigned a value, which means that placing it in Flash/PROGMEM is a waste of time and code space.
Specifically, what are you doing that causes the compiler to complain? This is the Programming section, where we expect to see code.
mromani
At runtime, PROGMEM behaves like a ROM. It is accessible in read-only mode, but its content cannot be changed. Therefore the only time when you can decide what to put into a PROGMEM-variable is at compile time.
Until you show the code, though, no direct advice can be given.
GoForSmoke
You might want to look into an SD card adapter or serial RAM chip(s) and use of the SPI bus.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
baum
My code is 10Kbytes and ~300 lines long... I'll just post setup() for now.
Code: [Select]
/* Science Research Program Yr. 1 2011 - 2012
* Reaction test
* Connections:
* Button, LED defines in includes.h; EEPROM to I2C SDA (A4) and SCL (A5)
#include <Wire.h>         //Communication with 24LC256
#include <EEPROM.h>       //storage for seeds and other data
#include <EEPROMAnything.h> //write anything to EEPROM.
#include "includes.h"     //preferences, defines, macros, etc.
unsigned long subjectNumber = 0; //subject number
//For time storage
byte currentRound;  //used like testNames[currentRound], zero indexed;
byte testNames[3]; //control, phone, or texting
/* stores times, in (rounded) milliseconds (raw timing done in micros)
* format always 0:contol, 1:phone, 2:text
unsigned long testTimes[3];
unsigned int memPointer = 0; //24LC256 memory pointer
byte testRunning = false;
//Start of program
void setup () {
  unsigned int prandSeed;
  Serial.begin(19200); //Change this in Serial Monitor!
  Wire.begin();
  Serial.println(F("SRP Reaction Timer")); //warning right here.
  pinMode(BUTTON_PIN, INPUT);
  digitalWrite(BUTTON_PIN, HIGH); //pullup
  pinMode(LED_PIN, OUTPUT);
  EEPROM_readAnything(PRANDSEED_ADDRESS, prandSeed);
  randomSeed(prandSeed);
It also will happen with other Serial.print strings throughout the program. But if this won't work, then why is it listed under the print() reference?
Thanks!
baum
PaulS
That certainly looks like it should compile.
Quote
Where do you see the F() documented?
baum
Quote
It does. But I get a warning.
and F() is @ the Serial.print() reference:
Quote
You can pass flash-memory based strings to Serial.print() by wrapping them with F(). For example :
Serial.print(F("Hello World"))
baum
Nevermind... it's an avr-gcc bug.
But on the topic of SRAM... how do I figure out how much of the RAM is being used? What would happen if I used it all up?
Thanks,
baum
PaulS
Quote
The amount of RAM in use changes as your program runs. So, there is no one "This is how much SRAM you are using" point. You can add calls to freeMemory() (once you search and find the function) to your code, at various places, to see how much you have at various points in the program.
Quote
Ugly stuff that is hard to track down.
mromani
Quote
Most likely the program would freeze or cause a reset of the uP.
baum
A very primitive count of my program shows that I have 60 bytes of variables (not counting the scope of variables) + 264 bytes of strings = 324 bytes total, neglecting scope. So I could go neurotic anyway and wrap the strings in F(), but I think I'll be fine: '328P has 2K...
Thanks a lot,
baum
mromani
It would be interesting if you started removing F() one by one, leaving the problematic one in place tough, and tell us when the error stops showing up...
baum
Sorry if I wasn't being clear... it comes up as a compiler warning (it still compiles). But it turns out that something in Arduino's Tone.cpp causes this warning, too, so I'll ignore it.
baum
mromani
I said "when the error stops showing up", not "when the sketch eventually compiles" :-)
