Topic: raw gyro and acc data to rate and angle (Read 3167 times) previous topic - next topic
sirbow2
Jan 17, 2012, 06:02 am Last Edit: Jan 17, 2012, 06:31 am by sirbow2 Reason: 1
im using the LSM and L3G4200D libraries for ACC and Gyro data, respectively, on my arduino. i need to calculate the Gyro rate and ACC angle from the raw data (x,y,z), and i have few sources explaining how(and i understand it: http://arduino.cc/forum/index.php?topic=58048.0 http://www.x-firm.com/?page_id=191)
datasheet Linear acceleration sensitivity(12-bit representation)
FS bit set to 00: 1 mg/digit
FS bit set to 01: 2 mg/digit
FS bit set to 11: 3.9 mg/digit
datasheet Gyro  Sensitivity
FS = 250 dps: 8.75 mdps/digit
FS = 500 dps: 17.50 mdps/digit
FS = 2000 dps: 7 mdps/digit
as you can see above, the gyro and acc have different possible sensitivities based on what settings are activated on the IC, but im not worried about that now. they are in this strange mg/digit format... My question is not how to do these rate/angle calculations but how to convert my sensors sensitivity measurement that is mg/digit format in the datasheet to quids(which is required for the calculations)?
i have found literally NO information on Quids besides mentions of it in angle calculation code, but no real explanation coversion ratios
thanks
edit, just a guess here... are "quids" for analog gyros only? im using i2c so... did i just ask a very dumb question?
http://dduino.blogspot.com all my Arduino/electronic projects!!!
{NEW} Getting Started, Learning, Reference + FAQ PDF!!:
[url]http://ar
