Topic: NT-T02B/ZABR1 cheap Chinese wireless serial (Read 2972 times) previous topic - next topic
celem
Jan 22, 2012, 01:11 am Last Edit: Jan 10, 2013, 04:44 pm by celem Reason: 1
I have been testing the NT-T02B transmitter and ZABR1 receiver, which are cheap Chinese wireless serial links available on eBay (search for 433 MHz  Arduino). For mine, I paid $5.49 including postage. I did not bother to connect proper length antennas (18cm) so my reliable operation distance was short. The VirtualWire library is not up to Arduino 1.0, so I had to replace WProgram.h with Arduino.h in the library files in order to successfully compile.
I setup the transmitter to sequentially number the transmitted messages so that I could look for drops on the receive side. See attached screen capture.
Working sketches are below.
For the transmit end:
Code: [Select]
#include <VirtualWire.h>
#include <string.h>
// rf_tx.ino
// Simple example of how to use VirtualWire to transmit messages
// Implements a simplex (one-way) transmitter with an TX-C1 module
// See VirtualWire.h for detailed API docs
// Original by: Mike McCauley (mikem@open.com.au)
// Copyright (C) 2008 Mike McCauley
#undef int
#undef abs
#undef double
#undef float
#undef round
int count = 0;
   Serial.begin(9600);  // Debugging only
   Serial.println("Transmitter setup");
   // Initialise
   vw_set_tx_pin(12);    // Set tx pin (default is 12)
   vw_setup(2000); // Bits per sec
   //const char *msg = "hello world";
   char msg[VW_MAX_MESSAGE_LEN];
   char scount[VW_MAX_MESSAGE_LEN];
   memset(msg,0,VW_MAX_MESSAGE_LEN-1);
   strcat(msg,"Message ");
   itoa(count++, scount, 10);
   strcat(msg,scount);
   digitalWrite(13, true); // Flash a light to show transmitting
   vw_send((uint8_t *)msg, strlen(msg));
   vw_wait_tx(); // Wait until the whole message is gone
   digitalWrite(13, false);
   Serial.println(msg);
   delay(200);
and for the receive end:
Code: [Select]
// rf_rx.ino
// Simple example of how to use VirtualWire to receive messages
// Implements a simplex (one-way) receiver with an Rx-B1 module
// Original Author: Mike McCauley (mikem@open.com.au)
#undef int
#undef abs
#undef double
#undef float
#undef round
   Serial.println("Rx setup");
   // Initialise the IO and ISR
   vw_set_rx_pin(11);    // Set Rx pin (defaults to 11)
   vw_rx_start();       // Start the receiver PLL running
   uint8_t buf[VW_MAX_MESSAGE_LEN];
   uint8_t buflen = VW_MAX_MESSAGE_LEN;
   // Get the last message received (without byte count or FCS)
   // Copy at most *buflen bytes, set *buflen to the actual number copied
   // Return true if there is a message and the FCS is OK
   if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
       buf[buflen] = 0;        // NULL terminate string received
       digitalWrite(13, true); // Flash a light to show received good message
// Message with a good checksum received, dump it.
Serial.print("Rx ");
       Serial.print(buflen, DEC);
       Serial.print(" ctrs - ");
       Serial.println((char *)buf);
