Hi, I'm very new to Arduino and I seem to be having a problem. I just wanted to make sure that the problem wasn't hardware related because it seems quite strange.
I am running an Arduino Nano 3.0 through USB. I have installed the ide and the drivers for the USB.
I then plug a 10k Pot into 5v to one side Gnd to the other and A0 to the middle signal lead(on the pot).
next I plug an led with resistor protection into pin D9.
then I open the ide and select AnalogInOutSerial from the examples, select my board(nano 3.0) from the tools menu, and click "upload"
the Arduino blinks for a while, then the IDE says "Done Uploading" no errors
I open the serial monitor and begin to play with the pot.
I get no output until I've turned the pot almost all the way up, then the led works but as expected, unfortunately once I do that, the serial monitor just shows 1023 for sensorValue and 255 for outputValue no matter what the position of the pot.
If I reset the board with the pot in any other position than all the way down serial monitor stays at 1023/255 if I turn it all the way down and reset the whole process starts over again,
not sure If what I'm doing wrong. I am running the example code with no alterations and I have set the IDE for the Nano 3.0 in the tools menu as well. I hope I'm just doing something stupid and I haven't wasted my $30USD =(
any help would be appreciated.
