Topic: Turn your Arduino into an AM radio transmitter! (Read 37695 times) previous topic - next topic
nickgammon
Jan 23, 2012, 11:14 pm Last Edit: Jan 24, 2012, 06:14 am by Nick Gammon Reason: 1
This simple project shows how you can make your Arduino into an AM-band transmitter.
Wiring: Plug a wire into pin D9.
Sketch:
Code: [Select]
const byte ANTENNA = 9;
 // set up Timer 1
 TCCR1A = _BV (COM1A0);  // toggle OC1A on Compare Match
 TCCR1B = _BV(WGM12) | _BV(CS10);   // CTC, no prescaler
 OCR1A =  9;       // compare A register value to 10 (zero relative)
 }  // end of setup
 pinMode (ANTENNA, OUTPUT);
 delay (500);
 pinMode (ANTENNA, INPUT);
 delay (300);
 }  // end of loop
Theory: The 16 MHz clock is divided by 10 (that is, 1.6 MHz) and that is used to toggle pin 9 at that rate, giving a frequency of 800 KHz, since one toggle turns the output on, and second toggle turns it off.
If you hold the Arduino near an AM radio tuned to around 800 KHz you should hear a hissing toggling on and off (like Morse code) as the carrier is turned on and off for 0.5 / 0.3 second intervals.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
robtillaart
FUN!
what stopped you from implementing a real morse lib into the code ? ;)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
nickgammon
Trying to keep it simple. :)
But I'm sure adding Morse into it would be pretty trivial.
Techone
Nice work.
I am going to try it. Just one wire... SIMPLE hook-up... and load the code... you are done...
Thank Nick Gammon
retrolefty
Well the next logical step would be to add in the tone library and allow a audio frequency tone output pin to modulate the timer output pin 'AM carrier frequency', then you would be talking true Amplitude Modulation, AM. However with everything being square wave outputs, don't now how easy it would be to combine these two signal outputs into a single AM output. Needs a little cleaver passive filtering and combining function circuit.
Lefty
3i3i
neoredstone
#6
Apr 09, 2015, 07:32 am Last Edit: Apr 09, 2015, 07:34 am by neoredstone
The OCR1A variable is related to the frequency.
The OCR1A variable is one less than the actual divisor.
OCR1A - Frequency
15 - 500 khz
14 - ~530 khz
13 - ~570 khz
12 - ~610 khz
11 - ~670 khz
10 - ~730 khz
9 - 800 khz
8 - ~890 khz
7 - 1000 khz
6 - ~1140 khz
5 - ~1330 khz
4 - 1600 khz
3 - 2000 khz
2 - ~2670 khz
1 - 4000 khz
0 - 8000 khz *would not recommend this setting
The formula is (16÷(OCR1A+1)÷2)×1000 = frequency in khz
neoredstone
#7
Apr 09, 2015, 07:41 am Last Edit: Apr 09, 2015, 07:49 am by neoredstone
The way to add tone to this, is by changing the delay between the two states, to get a 500 or 1000 hz (I'm not to sure) tone, you simply put in
Code: [Select]
 delay (1);
 delay (1);
And you can adjust the delay to meet your specifications.
headpigeons
This is really handy. I added some basic tone abilities and encoded twinkle twinkle.
Code: [Select]
unsigned long A = calcDelayTimeForFreq(440);
unsigned long B = calcDelayTimeForFreq(494);
unsigned long C = calcDelayTimeForFreq(523);
unsigned long D = calcDelayTimeForFreq(587);
unsigned long E = calcDelayTimeForFreq(659);
unsigned long F = calcDelayTimeForFreq(699);
unsigned long G = calcDelayTimeForFreq(784);
unsigned long _A2 = calcDelayTimeForFreq(880);
unsigned long rest = 1;
unsigned long q = 652;
unsigned long e = q/2;
unsigned long s = e/2;
unsigned long t = s/2;
unsigned long h = q*2;
unsigned long f = q*4;
  // set up Timer 1
}  // end of setup
void tone(unsigned long dTime, unsigned long playTime) {
  unsigned long end = millis() + playTime;
  while (end > millis()) {
    delayMicroseconds(dTime);
void note(unsigned long dTime, unsigned long playTime) {
  tone(dTime,playTime-50);
  tone(rest,50);
unsigned long calcDelayTimeForFreq(unsigned long freq) {
  return 500000/freq;
void twinkleTwinkle() {
  note(C,q);
  note(C,q);
  note(G,q);
  note(G,q);
  note(_A2,q);
  note(_A2,q);
  note(G,h);
  note(F,q);
  note(F,q);
  note(E,q);
  note(E,q);
  note(D,q);
  note(D,q);
  note(C,h);
  note(G,q);
  note(G,q);
  note(F,q);
  note(F,q);
  note(E,q);
  note(E,q);
  note(D,h);
  note(G,q);
  note(G,q);
  note(F,q);
  note(F,q);
  note(E,q);
  note(E,q);
  note(D,h);
  note(C,q);
  note(C,q);
  note(G,q);
  note(G,q);
  note(_A2,q);
  note(_A2,q);
  note(G,h);
  note(F,q);
  note(F,q);
  note(E,q);
  note(E,q);
  note(D,q);
  note(D,q);
  note(C,h);
void locateTone() {
  note(A,t);
  note(B,t);
  note(C,t);
  note(D,t);
  note(E,f);
  note(D,t);
  note(C,t);
  note(B,t);
  twinkleTwinkle();
I actually attached this to a disconnected sprinkler valve control wire and followed it around my yard with an am radio to find where the old valves were located. Pretty handy.
janvier123
THEBloxermanRBX
terryking228
Hmmm. Compiles and runs OK on 1.0.6 and 1.6.4 buts lots of compile errors on 1.6.7
What don't I understand??
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
zoomx
I got compiled all of two using 1.6.7 but in the second one by headpigeons I had to move the calcDelayTimeForFreq function before the others declarations, just after "const byte ANTENNA = 9;"
thexinex
This is a very fun project for learning about radio frequencies. I am wondering if there is a way to increase the range of the transmission. I have figured out how to change the frequency by modifying the OCR1A variable. Adding a longer antenna wire doesn't seem to make much of a difference. I have about 1ft of antenna wire attached and I can notice the signal works up to about 1-2 feet.
GoForSmoke
Would tuning the antenna length to some fraction of a full wavelength (375m at 800KHz) increase the output?
Would an opamp drive the signal far enough to be of any use?
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
