Topic: Problems finding Vcc using bandgap voltage method (Read 23533 times) previous topic - next topic
bilica
Thanks, I do have a spare analog input.
Would you mind giving more details (or other pointers) ? I am total beginner in this area.
Thanks again,
If you have a spare analog input pin, then a simple solution for any micro is to just wire a precision voltage reference chip to one input and use that value to map the correct range used for the other analog inputs of the ADC.
One of many possible examples:
http://www.analog.com/en/special-linear-functions/voltage-references/ad580/products/product.html
duntax
I plan to use this method to protect my LiPo battery pack. Does it make sense to monitor vcc to determine if there is enough power in my 7.4 V battery connected to Vin ? I hope drop in Vcc signals battery undervoltage but I have doubts.
retrolefty
#17
Jun 11, 2014, 06:11 pm Last Edit: Jun 11, 2014, 07:39 pm by retrolefty Reason: 1
No it won't. The Vin voltage goes to a voltage regulator that maintains a steady Vcc voltage even as Vin is dropping over time. A LiP0 two cell battery will have a voltage output from 8.4 vdc at full charge down to 3  6 vdc where most recommend to stop drawing power from it. You are better off using a voltage divider and measuring the battery directly via a analog input pin to decide when to alarm or shutdown.
duntax
duntax
And if I have two single cell batteries with a tap between them? Is it enough to measure the voltage at the tap without the divider?
retrolefty
Sounds good to me, saves needing the voltage divider.
