Topic: Wireless control system problem (Read 17806 times) previous topic - next topic
njkl44
Is this different to what you said earlier?
Quote
should i just power these servos with the 5v and gnd from the arduino or something else?
Certainly you should have the grounds common. I agree with that. And from the battery I would run a wire to the Arduino's "power in" socket (so it gets voltage regulated). And also direct from the battery to the motor shield.
Sounds OK, subject to seeing a schematic.
I believe it should be something like this?
njkl44
So i fallowed this diagram and it works fine :) one thing with the code is that it is really jumpy and random. The fingers do move when i move mine but there is a weird delay and the servos are pretty much always moving no matter if i flex my hand or not. We are really close!!!
nickgammon
Try increasing the baud rate to 115200 on both sides.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
njkl44
hmmm now nothing is happening. It is still receiving though. Do i need to reconfigure the xbees for 115200?
nickgammon
I'd forgotten about them. If you can, yes, if you are talking through them. I found with my robot car that a slow communication rate can make the response to controls a bit sluggish.
For example:
Code: [Select]
.123,100,92,42,99/
That's 18 bytes. At 9600 baud (960 characters per second) that would take 18.7 mS to send. Maybe the problem is something else.
njkl44
For example:
Code: [Select]
.123,100,92,42,99/
Could it be the delay? should i change that?
Code: [Select]
   Serial.print(".");
   Serial.print(servoVal1, DEC);
   Serial.print(",");
   Serial.print(servoVal2, DEC);
   Serial.print(",");
   Serial.print(servoVal3, DEC);
   Serial.print(",");
   Serial.print(servoVal4, DEC);
   Serial.print(",");
   Serial.print(RotationV1, DEC);
   Serial.print("/");
   delay(10);
nickgammon
You and your delays! Yes get rid of it unless you want a 10 mS sluggishness.
nickgammon
Also comment-out the debugging prints in the receiving end.
njkl44
That did it! perfect!! im going to see if the client wants the feedback system and ill do the code and post it on here
Thank you so much! I will credit you as much as i can! thank you :)
