Topic: Windows 7 and MEGA 2560 - doesn't install (Read 2719 times) previous topic - next topic
rcflyertim
I just purchsed my first Arduino board to learn about basic electronics.  Maybe I gooffed and purchased the wrong board!.  Should i have got the Unio board?
Here is what I have:
Computer: HP Pavilion 9700 x64 with 4meg ram
OS: Windows 7 with Service Pack 1 Installed
Arduino: Mega 2560
I downloaded the software "windows".  Used WINZip to decompress the files.  Hooked up the board and got one blinking yellow light and one steady(on) green light.  Went to Device Manager and found usb connection and open the Arduino 1.0 file and drivers folder and only see FTDI drivers.  I have tried all that are listed (amd64, i386, static) and they don't work.  What am I doing wrong or missing?
GaryP
Are you the administrator level user, does your account have a power to change drivers? We had the same problem once, Vista and Window7 are too tight sometimes.
Cheers,
Kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
madworm
rcflyertim
I am running as Admin but that is not helping.  I am not sure what the second post meant by look closer!??  closer at what??????
madworm
You said you didn't find the drivers for your board. In the attached image it shows where they are.
rcflyertim
what attached image are you referring to?
pYro_65
In the arduino folder (where ever you unzipped it to ), there is a folder called 'drivers' and inside that is the *.inf files.
1. Plug in arduino into a system USB port ( not a usb hub or helper ports at front of PC ) then Right click 'My Computer'
2. Click 'Properties'
3. In the properties window, click 'Device Manager'
4. In the device manager it will show a listing 'Other Devices' and inside that is 'Arduino X' where x is the type of board.
5. If it isn't there click the refresh button ( or menu Action->Scan for hardware changes )
6. Right click on the arduino listing, click 'Update Driver Software'
7. Click 'Browse my computer for driver'
8. Point the file browse button to the drivers folder in the arduino install. ( mentioned at top )
Forum Mod anyone?
https://arduino.land/Moduino/
madworm
Quote
The image, which is attached to one of my previous posts.
It is only visible if you're logged in.
