Topic: core13: An Arduino core for the Attiny13 *testers wanted* (Read 178902 times) previous topic - next topic
bipsen
Any chance of a release, that will fit the Arduino 1.8.x toolchain?
As far as I can see, the location of the files need to be adjusted...
hansibull
There exist various forks of core13 on Github that works with IDE 1.8.x.
MicroCore is probably the best one out there with lots of improvements (both efficiency and features) compared to core13.
MightyCore -  ATmega1284, mega644, mega324, mega164, mega32, mega16, mega8535
Github.com/MCUdude/MightyCore
MiniCore - ATmega8, mega48, mega88, mega168, mega328
Github.com/MCUdude/MiniCore
smeezekitty
I am not currently set up to work with Tiny13 so the development is on hold. At this point, it is best just to use one of the forks. There are a number of differences -- some are clearly improvements and others have upsides and downsides. Either way, you could always transplant bits of code if it doesn't work exactly how you want. The important thing is that they are maintained to be compatible with the newest version of the Arduino IDE. Something I always had trouble with because it changes so often
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
