Just received two attiny13a PU.
Plan 1: use it to drive a 4-pin RGB led. User shud be able to control intensity of each color using a push-button.
Plan 2: use it to drive a single(may be multiple, but don't really need it now) WS2812 based neoPixcel. Here also user should be able to control the individual color using push buttons.
In both of above case, either 3 push switch can be used to change individual color intensity with a step value of say 32 or 64. OR 2 push switch can be used; one for select the color to change and other to change the color intensity by a step value.
Should I burn a bootloader to the tiny? Please suggest how can I keep the code below 1K.
