Topic: SMD 5050 5M LED Problem (Read 2239 times) previous topic - next topic
meyer_lanski
Hello everyone,
I have a problem I was hoping someone in this forum could help me out with. I have searched online for weeks but could not find the correct answer anywhere!
I purchased a 5m strip and when connecting to power supply the light at the end of the 5m is not as bright as the beginning. As though power is lost. What could be the cause of this?
Any help would be greatly appreciated!
I have the following:
5m rgb smd 5050 LEDs (300 leds total) (12v 1.2amp/m)
1 24 IR Remote
1 12v 7amp power supply
Here are the links to what I have purchased:
LEDS:
http://www.ebay.ca/itm/160703608361?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
REMOTE:
http://www.ebay.ca/itm/390379498690?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
POWER SUPPLY:
http://www.ebay.ca/itm/220915150719?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
xl97
no clue.. (sorry)
maybe meter the power supply check out put..
then inspect strip to see if resistors are all the same..etc
the 5050 LEDS actually have '3' smd leds  under the same 'dome'..  maybe a broken solder point and not all are on?
Grumpy_Mike
Quote
Probably just a faulty strip.
CrossRoads
Or voltage loss down the internal power conductor.
If you connect 12V/Gnd to both ends with separate wires, does it get your brightness back?
