Topic: IR LED problem (Read 1 time) previous topic - next topic
bri01
Hello
I guess this is a very silly question..but I found no answer at the internet.
I try to rebuild the Arduino "Blink" Sketch with an IR LED. It works fine if I connect the IR LED directly to the pin 13 and ground. But when I connect the IR LED through a cable to my breadboard and after to the ground it appears no light on my camera.
Can anybody help me?
Many thanks!
runaway_pancake
Maybe the wire you are using is too thin, not making good connection in the arduino headers or the breadboard contacts.
(I hope you're using a resistor in series with that IR LED.)
If all else fails, post a picture of your set-up.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Grumpy_Mike
Quote
Then simply you have not done what you think you have done.
Yes you need a resistor, if you did not use one maybe you have fried the output pin of your arduino, which might explain why it no longer works.
