Topic: 'client' was not declared in this scope (Read 13082 times) previous topic - next topic
oppedahl
I will be grateful for help with this problem.
My goal, of course, is to write some fairly clean code, using functions as a way of cleaning things up.  I would like to do some of the "client.print" activity within a function, as shown here.
Unfortunately it won't compile.  The compiler says "'client' was not declared in this scope", pointing at the first use of 'client' in the function "analytics".
I assume there is something I must do to explain to the compiler that it should be able to make use of "client" within the function.
Quote
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x80, 0xB8 };
IPAddress ip(192,168,113,90);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(81);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  // listen for incoming clients
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println();
client.print("Getting ready for 'hello world'");
analytics();
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
void analytics()
client.print("Hello, world!");
AWOL
Put your declaration of client outside of loop ().
The scope error is a clue.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
oppedahl
Thank you for your posting which says to "Put your declaration of client outside of loop ()."
I am sorry but I am so new at this that I do not know how to do what you said.  I would be grateful if you can say something like "insert a new line outside of loop() that says X".
AWOL
Quote
EthernetClient client;
oppedahl
Thank you for your posting.  Indeed your suggestion of "EthernetClient client;" made the compile eror go away.
When I run this sketch, the LED lights up, but "hello world" does not show up on the web page.  The "getting ready" shows up on the web page, but the "hello world" from the function does not.
I would be grateful if you can tell me what I am doing wrong.
Quote
#include <SPI.h>
  server.begin();
  pinMode(4,OUTPUT);
if (client) {
          client.println();
    client.println("Getting ready for 'hello world' <br />");
analytics();
        if (c == '\n') {
    delay(1);
    client.stop();
void analytics()
  digitalWrite(4,HIGH); //turn on a yellow LED
  digitalWrite(4,LOW);
AWOL
You've still got a client declaration inside loop.
Change it to an assignment.
zoomkat
Quote
It appears that you may have previously closed the connection to the client (client.stop();) before you print "hello world. Also, you are using quote tags instead of code tags (#) to post your code
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
oppedahl
For the benefit of other new users such as myself, the fix turned out to be the following:
  • In loop(), find the line "EthernetClient client = server.available();" and change it to "client = server.available();".  In other words, delete "EthernetClient ".
  • Outside of loop(), insert a new line "EthernetClient client;"
The idea was that I had started with the Example of Web Server, the sketch that permits a visitor to visit a web site (inside the Arduino) and to see the values of the five A-to-D inputs.  I wanted to do some of the "print.client" activity in a function instead of in the main program.  This fix permits such a thing.
Again, thank you for posting.
Oh, and if anyone wishes to visit the web page, it is at http://wx1.oppedahl.com:81/.  Just now it is very much "under construction" but maybe later people will find it to be interesting.  I will be looking for volunteers to send me emails with data-pairs, each data pair providing an A-to-D value and the corresponding human-readable temperature on a webcam image.
kjparduino
Carl,
Thank you for posting the solution in easy to understand instructions and the explanation.
Helped me do a task and understand a little more about Arduino coding (and I'm sure others, too).
KJP
robweber
This also works for WiFiClient.
Outside of Loop put WiFiClient client;
Inside of loop put client = server.available();
Thank you oppedahl.
hooverhouse
not sure what it wants here? if anyone can help i would greatly appreciate it.
'MqttClient' was not declared in this scope
#ifdef USE_EMULATION
      UdpDisconnect();
#endif  // USE_EMULATION
      if (Settings.flag.mqtt_enabled) {
        MqttClient.disconnect();
