Topic: Digital read/write pinMode : fast execution (Read 16835 times) previous topic - next topic
nickgammon
Feb 09, 2012, 06:46 am Last Edit: Feb 09, 2012, 09:09 pm by Nick Gammon Reason: 1
Every now and then I need to turn pins on or off quickly (like in an interrupt service routine) and have to reach for my "pins mapping" sheet to see exactly what port I required, and what bit.
With a small Lua script I generated a file which has all the input/output read/write mappings you should need. This is for the Atmega328 (eg. Uno, Duemilanove).
To use, just skim down for the pinMode/digitalRead/digitalWrite you want, and copy and paste that line.
Atmega328:
Code: [Select]
// --- PIN MODE: OUTPUT  ---
  DDRD |= _BV (0); // pinMode (0, OUTPUT);
  DDRD |= _BV (1); // pinMode (1, OUTPUT);
  DDRD |= _BV (2); // pinMode (2, OUTPUT);
  DDRD |= _BV (3); // pinMode (3, OUTPUT);
  DDRD |= _BV (4); // pinMode (4, OUTPUT);
  DDRD |= _BV (5); // pinMode (5, OUTPUT);
  DDRD |= _BV (6); // pinMode (6, OUTPUT);
  DDRD |= _BV (7); // pinMode (7, OUTPUT);
  DDRB |= _BV (0); // pinMode (8, OUTPUT);
  DDRB |= _BV (1); // pinMode (9, OUTPUT);
  DDRB |= _BV (2); // pinMode (10, OUTPUT);
  DDRB |= _BV (3); // pinMode (11, OUTPUT);
  DDRB |= _BV (4); // pinMode (12, OUTPUT);
  DDRB |= _BV (5); // pinMode (13, OUTPUT);
  DDRC |= _BV (0); // pinMode (A0, OUTPUT);
  DDRC |= _BV (1); // pinMode (A1, OUTPUT);
  DDRC |= _BV (2); // pinMode (A2, OUTPUT);
  DDRC |= _BV (3); // pinMode (A3, OUTPUT);
  DDRC |= _BV (4); // pinMode (A4, OUTPUT);
  DDRC |= _BV (5); // pinMode (A5, OUTPUT);
// --- PIN MODE: INPUT  ---
  DDRD &= ~_BV (0); // pinMode (0, INPUT);
  DDRD &= ~_BV (1); // pinMode (1, INPUT);
  DDRD &= ~_BV (2); // pinMode (2, INPUT);
  DDRD &= ~_BV (3); // pinMode (3, INPUT);
  DDRD &= ~_BV (4); // pinMode (4, INPUT);
  DDRD &= ~_BV (5); // pinMode (5, INPUT);
  DDRD &= ~_BV (6); // pinMode (6, INPUT);
  DDRD &= ~_BV (7); // pinMode (7, INPUT);
  DDRB &= ~_BV (0); // pinMode (8, INPUT);
  DDRB &= ~_BV (1); // pinMode (9, INPUT);
  DDRB &= ~_BV (2); // pinMode (10, INPUT);
  DDRB &= ~_BV (3); // pinMode (11, INPUT);
  DDRB &= ~_BV (4); // pinMode (12, INPUT);
  DDRB &= ~_BV (5); // pinMode (13, INPUT);
  DDRC &= ~_BV (0); // pinMode (A0, INPUT);
  DDRC &= ~_BV (1); // pinMode (A1, INPUT);
  DDRC &= ~_BV (2); // pinMode (A2, INPUT);
  DDRC &= ~_BV (3); // pinMode (A3, INPUT);
  DDRC &= ~_BV (4); // pinMode (A4, INPUT);
  DDRC &= ~_BV (5); // pinMode (A5, INPUT);
// --- DIGITAL WRITE: HIGH  ---
  PORTD |= _BV (0); // digitalWrite (0, HIGH);
  PORTD |= _BV (1); // digitalWrite (1, HIGH);
  PORTD |= _BV (2); // digitalWrite (2, HIGH);
  PORTD |= _BV (3); // digitalWrite (3, HIGH);
  PORTD |= _BV (4); // digitalWrite (4, HIGH);
  PORTD |= _BV (5); // digitalWrite (5, HIGH);
  PORTD |= _BV (6); // digitalWrite (6, HIGH);
  PORTD |= _BV (7); // digitalWrite (7, HIGH);
  PORTB |= _BV (0); // digitalWrite (8, HIGH);
  PORTB |= _BV (1); // digitalWrite (9, HIGH);
  PORTB |= _BV (2); // digitalWrite (10, HIGH);
  PORTB |= _BV (3); // digitalWrite (11, HIGH);
  PORTB |= _BV (4); // digitalWrite (12, HIGH);
  PORTB |= _BV (5); // digitalWrite (13, HIGH);
  PORTC |= _BV (0); // digitalWrite (A0, HIGH);
  PORTC |= _BV (1); // digitalWrite (A1, HIGH);
  PORTC |= _BV (2); // digitalWrite (A2, HIGH);
  PORTC |= _BV (3); // digitalWrite (A3, HIGH);
  PORTC |= _BV (4); // digitalWrite (A4, HIGH);
  PORTC |= _BV (5); // digitalWrite (A5, HIGH);
// --- DIGITAL WRITE: LOW  ---
  PORTD &= ~_BV (0); // digitalWrite (0, LOW);
  PORTD &= ~_BV (1); // digitalWrite (1, LOW);
  PORTD &= ~_BV (2); // digitalWrite (2, LOW);
  PORTD &= ~_BV (3); // digitalWrite (3, LOW);
  PORTD &= ~_BV (4); // digitalWrite (4, LOW);
  PORTD &= ~_BV (5); // digitalWrite (5, LOW);
  PORTD &= ~_BV (6); // digitalWrite (6, LOW);
  PORTD &= ~_BV (7); // digitalWrite (7, LOW);
  PORTB &= ~_BV (0); // digitalWrite (8, LOW);
  PORTB &= ~_BV (1); // digitalWrite (9, LOW);
  PORTB &= ~_BV (2); // digitalWrite (10, LOW);
  PORTB &= ~_BV (3); // digitalWrite (11, LOW);
  PORTB &= ~_BV (4); // digitalWrite (12, LOW);
  PORTB &= ~_BV (5); // digitalWrite (13, LOW);
  PORTC &= ~_BV (0); // digitalWrite (A0, LOW);
  PORTC &= ~_BV (1); // digitalWrite (A1, LOW);
  PORTC &= ~_BV (2); // digitalWrite (A2, LOW);
  PORTC &= ~_BV (3); // digitalWrite (A3, LOW);
  PORTC &= ~_BV (4); // digitalWrite (A4, LOW);
  PORTC &= ~_BV (5); // digitalWrite (A5, LOW);
// --- DIGITAL READ  ---
  x = (PIND & _BV (0)) == 0; // digitalRead (0);
  x = (PIND & _BV (1)) == 0; // digitalRead (1);
  x = (PIND & _BV (2)) == 0; // digitalRead (2);
  x = (PIND & _BV (3)) == 0; // digitalRead (3);
  x = (PIND & _BV (4)) == 0; // digitalRead (4);
  x = (PIND & _BV (5)) == 0; // digitalRead (5);
  x = (PIND & _BV (6)) == 0; // digitalRead (6);
  x = (PIND & _BV (7)) == 0; // digitalRead (7);
  x = (PINB & _BV (0)) == 0; // digitalRead (8);
  x = (PINB & _BV (1)) == 0; // digitalRead (9);
  x = (PINB & _BV (2)) == 0; // digitalRead (10);
  x = (PINB & _BV (3)) == 0; // digitalRead (11);
  x = (PINB & _BV (4)) == 0; // digitalRead (12);
  x = (PINB & _BV (5)) == 0; // digitalRead (13);
  x = (PINC & _BV (0)) == 0; // digitalRead (A0);
  x = (PINC & _BV (1)) == 0; // digitalRead (A1);
  x = (PINC & _BV (2)) == 0; // digitalRead (A2);
  x = (PINC & _BV (3)) == 0; // digitalRead (A3);
  x = (PINC & _BV (4)) == 0; // digitalRead (A4);
  x = (PINC & _BV (5)) == 0; // digitalRead (A5);
Lua code to generate this:
Code: [Select]
pins = {
  { name = "0",  port = "D", bit = 0 },
  { name = "1",  port = "D", bit = 1 },
  { name = "2",  port = "D", bit = 2 },
  { name = "3",  port = "D", bit = 3 },
  { name = "4",  port = "D", bit = 4 },
  { name = "5",  port = "D", bit = 5 },
  { name = "6",  port = "D", bit = 6 },
  { name = "7",  port = "D", bit = 7 },
  { name = "8",  port = "B", bit = 0 },
  { name = "9",  port = "B", bit = 1 },
  { name = "10", port = "B", bit = 2 },
  { name = "11", port = "B", bit = 3 },
  { name = "12", port = "B", bit = 4 },
  { name = "13", port = "B", bit = 5 },
  { name = "A0", port = "C", bit = 0 },
  { name = "A1", port = "C", bit = 1 },
  { name = "A2", port = "C", bit = 2 },
  { name = "A3", port = "C", bit = 3 },
  { name = "A4", port = "C", bit = 4 },
  { name = "A5", port = "C", bit = 5 },
} -- end of pins
print ""
print ("// --- PIN MODE: OUTPUT  --- ")
print ""
for k, pin in ipairs (pins) do
  print ("  DDR" .. pin.port .. " |= _BV (" .. pin.bit .. "); // pinMode (" .. pin.name .. ", OUTPUT);")
end -- for
print ""
print ("// --- PIN MODE: INPUT  --- ")
print ""
  print ("  DDR" .. pin.port .. " &= ~_BV (" .. pin.bit .. "); // pinMode (" .. pin.name .. ", INPUT);")
end -- for
print ""
print ("// --- DIGITAL WRITE: HIGH  --- ")
print ""
  print ("  PORT" .. pin.port .. " |= _BV (" .. pin.bit .. "); // digitalWrite (" .. pin.name .. ", HIGH);")
end -- for
print ""
print ("// --- DIGITAL WRITE: LOW  --- ")
print ""
  print ("  PORT" .. pin.port .. " &= ~_BV (" .. pin.bit .. "); // digitalWrite (" .. pin.name .. ", LOW);")
end -- for
print ""
print ("// --- DIGITAL READ  --- ")
print ""
  print ("  x = (PIN" .. pin.port .. " & _BV (" .. pin.bit .. ")) == 0; // digitalRead (" .. pin.name .. ");")
end -- for
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
CrossRoads
Cool. Can you create same for a 1284 please?
nickgammon
I know this sounds crazy, but I'm struggling to find the mappings (pin "name" to port). Can you fill this in? Basically it means pin D0 is port D, bit 0, and so on. Then I can run the script on it.
Code: [Select]
pins = {
} -- end of pins
CrossRoads
Pins as defined by maniacbug, following Sanguino lead I think.
Code: [Select]
pins = {
{ name = "0", port = "B", bit = 0 },
{ name = "1", port = "B", bit = 1 },
{ name = "2", port = "B", bit = 2 },
{ name = "3", port = "B", bit = 3 },
{ name = "4", port = "B", bit = 4 },
{ name = "5", port = "B", bit = 5 },
{ name = "6", port = "B", bit = 6 },
{ name = "7", port = "B", bit = 7 },
{ name = "8", port = "D", bit = 0 },
{ name = "9", port = "D", bit = 1 },
{ name = "10", port = "D", bit = 2 },
{ name = "11", port = "D", bit = 3 },
{ name = "12", port = "D", bit = 4 },
{ name = "13", port = "D", bit = 5 },
{ name = "14", port = "D", bit = 6 },
{ name = "15", port = "D", bit = 7 },
{ name = "16", port = "C", bit = 0 },
{ name = "17", port = "C", bit = 1 },
{ name = "18", port = "C", bit = 2 },
{ name = "18", port = "C", bit = 3 },
{ name = "20", port = "C", bit = 4 },
{ name = "21", port = "C", bit = 5 },
{ name = "22", port = "C", bit = 6 },
{ name = "23", port = "C", bit = 7 },
{ name = "A0", port = "A", bit = 0 },
{ name = "A1", port = "A", bit = 1 },
{ name = "A2", port = "A", bit = 2 },
{ name = "A3", port = "A", bit = 3 },
{ name = "A4", port = "A", bit = 4 },
{ name = "A5", port = "A", bit = 5 },
{ name = "A6", port = "A", bit = 6 },
{ name = "A7", port = "A", bit = 7 },
} -- end of pins
nickgammon
#4
Feb 09, 2012, 07:42 am Last Edit: Feb 09, 2012, 09:10 pm by Nick Gammon Reason: 1
Given the above data:
For the Atmega1284:
Code: [Select]
  DDRB |= _BV (0); // pinMode (0, OUTPUT);
  DDRB |= _BV (1); // pinMode (1, OUTPUT);
  DDRB |= _BV (2); // pinMode (2, OUTPUT);
  DDRB |= _BV (3); // pinMode (3, OUTPUT);
  DDRB |= _BV (4); // pinMode (4, OUTPUT);
  DDRB |= _BV (5); // pinMode (5, OUTPUT);
  DDRB |= _BV (6); // pinMode (6, OUTPUT);
  DDRB |= _BV (7); // pinMode (7, OUTPUT);
  DDRD |= _BV (0); // pinMode (8, OUTPUT);
  DDRD |= _BV (1); // pinMode (9, OUTPUT);
  DDRD |= _BV (2); // pinMode (10, OUTPUT);
  DDRD |= _BV (3); // pinMode (11, OUTPUT);
  DDRD |= _BV (4); // pinMode (12, OUTPUT);
  DDRD |= _BV (5); // pinMode (13, OUTPUT);
  DDRD |= _BV (6); // pinMode (14, OUTPUT);
  DDRD |= _BV (7); // pinMode (15, OUTPUT);
  DDRC |= _BV (0); // pinMode (16, OUTPUT);
  DDRC |= _BV (1); // pinMode (17, OUTPUT);
  DDRC |= _BV (2); // pinMode (18, OUTPUT);
  DDRC |= _BV (3); // pinMode (18, OUTPUT);
  DDRC |= _BV (4); // pinMode (20, OUTPUT);
  DDRC |= _BV (5); // pinMode (21, OUTPUT);
  DDRC |= _BV (6); // pinMode (22, OUTPUT);
  DDRC |= _BV (7); // pinMode (23, OUTPUT);
  DDRA |= _BV (0); // pinMode (A0, OUTPUT);
  DDRA |= _BV (1); // pinMode (A1, OUTPUT);
  DDRA |= _BV (2); // pinMode (A2, OUTPUT);
  DDRA |= _BV (3); // pinMode (A3, OUTPUT);
  DDRA |= _BV (4); // pinMode (A4, OUTPUT);
  DDRA |= _BV (5); // pinMode (A5, OUTPUT);
  DDRA |= _BV (6); // pinMode (A6, OUTPUT);
  DDRA |= _BV (7); // pinMode (A7, OUTPUT);
  DDRB &= ~_BV (0); // pinMode (0, INPUT);
  DDRB &= ~_BV (1); // pinMode (1, INPUT);
  DDRB &= ~_BV (2); // pinMode (2, INPUT);
  DDRB &= ~_BV (3); // pinMode (3, INPUT);
  DDRB &= ~_BV (4); // pinMode (4, INPUT);
  DDRB &= ~_BV (5); // pinMode (5, INPUT);
  DDRB &= ~_BV (6); // pinMode (6, INPUT);
  DDRB &= ~_BV (7); // pinMode (7, INPUT);
  DDRD &= ~_BV (0); // pinMode (8, INPUT);
  DDRD &= ~_BV (1); // pinMode (9, INPUT);
  DDRD &= ~_BV (2); // pinMode (10, INPUT);
  DDRD &= ~_BV (3); // pinMode (11, INPUT);
  DDRD &= ~_BV (4); // pinMode (12, INPUT);
  DDRD &= ~_BV (5); // pinMode (13, INPUT);
  DDRD &= ~_BV (6); // pinMode (14, INPUT);
  DDRD &= ~_BV (7); // pinMode (15, INPUT);
  DDRC &= ~_BV (0); // pinMode (16, INPUT);
  DDRC &= ~_BV (1); // pinMode (17, INPUT);
  DDRC &= ~_BV (2); // pinMode (18, INPUT);
  DDRC &= ~_BV (3); // pinMode (18, INPUT);
  DDRC &= ~_BV (4); // pinMode (20, INPUT);
  DDRC &= ~_BV (5); // pinMode (21, INPUT);
  DDRC &= ~_BV (6); // pinMode (22, INPUT);
  DDRC &= ~_BV (7); // pinMode (23, INPUT);
  DDRA &= ~_BV (0); // pinMode (A0, INPUT);
  DDRA &= ~_BV (1); // pinMode (A1, INPUT);
  DDRA &= ~_BV (2); // pinMode (A2, INPUT);
  DDRA &= ~_BV (3); // pinMode (A3, INPUT);
  DDRA &= ~_BV (4); // pinMode (A4, INPUT);
  DDRA &= ~_BV (5); // pinMode (A5, INPUT);
  DDRA &= ~_BV (6); // pinMode (A6, INPUT);
  DDRA &= ~_BV (7); // pinMode (A7, INPUT);
  PORTB |= _BV (0); // digitalWrite (0, HIGH);
  PORTB |= _BV (1); // digitalWrite (1, HIGH);
  PORTB |= _BV (2); // digitalWrite (2, HIGH);
  PORTB |= _BV (3); // digitalWrite (3, HIGH);
  PORTB |= _BV (4); // digitalWrite (4, HIGH);
  PORTB |= _BV (5); // digitalWrite (5, HIGH);
  PORTB |= _BV (6); // digitalWrite (6, HIGH);
  PORTB |= _BV (7); // digitalWrite (7, HIGH);
  PORTD |= _BV (0); // digitalWrite (8, HIGH);
  PORTD |= _BV (1); // digitalWrite (9, HIGH);
  PORTD |= _BV (2); // digitalWrite (10, HIGH);
  PORTD |= _BV (3); // digitalWrite (11, HIGH);
  PORTD |= _BV (4); // digitalWrite (12, HIGH);
  PORTD |= _BV (5); // digitalWrite (13, HIGH);
  PORTD |= _BV (6); // digitalWrite (14, HIGH);
  PORTD |= _BV (7); // digitalWrite (15, HIGH);
  PORTC |= _BV (0); // digitalWrite (16, HIGH);
  PORTC |= _BV (1); // digitalWrite (17, HIGH);
  PORTC |= _BV (2); // digitalWrite (18, HIGH);
  PORTC |= _BV (3); // digitalWrite (18, HIGH);
  PORTC |= _BV (4); // digitalWrite (20, HIGH);
  PORTC |= _BV (5); // digitalWrite (21, HIGH);
  PORTC |= _BV (6); // digitalWrite (22, HIGH);
  PORTC |= _BV (7); // digitalWrite (23, HIGH);
  PORTA |= _BV (0); // digitalWrite (A0, HIGH);
  PORTA |= _BV (1); // digitalWrite (A1, HIGH);
  PORTA |= _BV (2); // digitalWrite (A2, HIGH);
  PORTA |= _BV (3); // digitalWrite (A3, HIGH);
  PORTA |= _BV (4); // digitalWrite (A4, HIGH);
  PORTA |= _BV (5); // digitalWrite (A5, HIGH);
  PORTA |= _BV (6); // digitalWrite (A6, HIGH);
  PORTA |= _BV (7); // digitalWrite (A7, HIGH);
  PORTB &= ~_BV (0); // digitalWrite (0, LOW);
  PORTB &= ~_BV (1); // digitalWrite (1, LOW);
  PORTB &= ~_BV (2); // digitalWrite (2, LOW);
  PORTB &= ~_BV (3); // digitalWrite (3, LOW);
  PORTB &= ~_BV (4); // digitalWrite (4, LOW);
  PORTB &= ~_BV (5); // digitalWrite (5, LOW);
  PORTB &= ~_BV (6); // digitalWrite (6, LOW);
  PORTB &= ~_BV (7); // digitalWrite (7, LOW);
  PORTD &= ~_BV (0); // digitalWrite (8, LOW);
  PORTD &= ~_BV (1); // digitalWrite (9, LOW);
  PORTD &= ~_BV (2); // digitalWrite (10, LOW);
  PORTD &= ~_BV (3); // digitalWrite (11, LOW);
  PORTD &= ~_BV (4); // digitalWrite (12, LOW);
  PORTD &= ~_BV (5); // digitalWrite (13, LOW);
  PORTD &= ~_BV (6); // digitalWrite (14, LOW);
  PORTD &= ~_BV (7); // digitalWrite (15, LOW);
  PORTC &= ~_BV (0); // digitalWrite (16, LOW);
  PORTC &= ~_BV (1); // digitalWrite (17, LOW);
  PORTC &= ~_BV (2); // digitalWrite (18, LOW);
  PORTC &= ~_BV (3); // digitalWrite (18, LOW);
  PORTC &= ~_BV (4); // digitalWrite (20, LOW);
  PORTC &= ~_BV (5); // digitalWrite (21, LOW);
  PORTC &= ~_BV (6); // digitalWrite (22, LOW);
  PORTC &= ~_BV (7); // digitalWrite (23, LOW);
  PORTA &= ~_BV (0); // digitalWrite (A0, LOW);
  PORTA &= ~_BV (1); // digitalWrite (A1, LOW);
  PORTA &= ~_BV (2); // digitalWrite (A2, LOW);
  PORTA &= ~_BV (3); // digitalWrite (A3, LOW);
  PORTA &= ~_BV (4); // digitalWrite (A4, LOW);
  PORTA &= ~_BV (5); // digitalWrite (A5, LOW);
  PORTA &= ~_BV (6); // digitalWrite (A6, LOW);
  PORTA &= ~_BV (7); // digitalWrite (A7, LOW);
  x = (PINB & _BV (0)) == 0; // digitalRead (0);
  x = (PINB & _BV (1)) == 0; // digitalRead (1);
  x = (PINB & _BV (2)) == 0; // digitalRead (2);
  x = (PINB & _BV (3)) == 0; // digitalRead (3);
  x = (PINB & _BV (4)) == 0; // digitalRead (4);
  x = (PINB & _BV (5)) == 0; // digitalRead (5);
  x = (PINB & _BV (6)) == 0; // digitalRead (6);
  x = (PINB & _BV (7)) == 0; // digitalRead (7);
  x = (PIND & _BV (0)) == 0; // digitalRead (8);
  x = (PIND & _BV (1)) == 0; // digitalRead (9);
  x = (PIND & _BV (2)) == 0; // digitalRead (10);
  x = (PIND & _BV (3)) == 0; // digitalRead (11);
  x = (PIND & _BV (4)) == 0; // digitalRead (12);
  x = (PIND & _BV (5)) == 0; // digitalRead (13);
  x = (PIND & _BV (6)) == 0; // digitalRead (14);
  x = (PIND & _BV (7)) == 0; // digitalRead (15);
  x = (PINC & _BV (0)) == 0; // digitalRead (16);
  x = (PINC & _BV (1)) == 0; // digitalRead (17);
  x = (PINC & _BV (2)) == 0; // digitalRead (18);
  x = (PINC & _BV (3)) == 0; // digitalRead (18);
  x = (PINC & _BV (4)) == 0; // digitalRead (20);
  x = (PINC & _BV (5)) == 0; // digitalRead (21);
  x = (PINC & _BV (6)) == 0; // digitalRead (22);
  x = (PINC & _BV (7)) == 0; // digitalRead (23);
  x = (PINA & _BV (0)) == 0; // digitalRead (A0);
  x = (PINA & _BV (1)) == 0; // digitalRead (A1);
  x = (PINA & _BV (2)) == 0; // digitalRead (A2);
  x = (PINA & _BV (3)) == 0; // digitalRead (A3);
  x = (PINA & _BV (4)) == 0; // digitalRead (A4);
  x = (PINA & _BV (5)) == 0; // digitalRead (A5);
  x = (PINA & _BV (6)) == 0; // digitalRead (A6);
  x = (PINA & _BV (7)) == 0; // digitalRead (A7);
CrossRoads
Thanks Nick.
So to make bit D0 toggle really fast a few times, I would just do this?
Code: [Select]
for (x=0; x<10; x=x+1){
do I need the DDRB anyplace except in void setup() if the pin will always be an output?
j514
Nice post, Nick.  How about the Mega 2560 ?
a][+ ascii express, 110/300 novation cat, xmodem
CrossRoads
Gotta do your part j514 - post the ports/pin assignments like I did for the 1284.
Take that one and build up for all the 2560 pins.
nickgammon
Thanks Nick.
Code: [Select]
That looks good.
No. It's like pinMode. Only need to do it once.
j514
Quote
Fair enough.  Just to confirm before I get going at it, using http://arduino.cc/en/Hacking/PinMapping2560 as the source, does
Code: [Select]
5 PE3 ( OC3A/AIN1 )
convert to:
Code: [Select]
{ name = "5", port = "E", bit = 3 },
or am I mistaken?
CrossRoads
I believe you are correct.
Note that not all ports/pins are brought out on the Arduino Mega, so there will be some holes in the listing.
j514
Okay here we go.
Code: [Select]
{ name = "1", port = "G", bit = 5 },
{ name = "2", port = "E", bit = 0 },
{ name = "3", port = "E", bit = 1 },
{ name = "4", port = "E", bit = 2 },
{ name = "6", port = "E", bit = 4 },
{ name = "7", port = "E", bit = 5 },
{ name = "8", port = "E", bit = 6 },
{ name = "9", port = "E", bit = 7 },
{ name = "12", port = "H", bit = 0 },
{ name = "13", port = "H", bit = 1 },
{ name = "14", port = "H", bit = 2 },
{ name = "15", port = "H", bit = 3 },
{ name = "16", port = "H", bit = 4 },
{ name = "17", port = "H", bit = 5 },
{ name = "18", port = "H", bit = 6 },
{ name = "19", port = "B", bit = 0 },
{ name = "20", port = "B", bit = 1 },
{ name = "21", port = "B", bit = 2 },
{ name = "22", port = "B", bit = 3 },
{ name = "23", port = "B", bit = 4 },
{ name = "24", port = "B", bit = 5 },
{ name = "25", port = "B", bit = 6 },
{ name = "26", port = "B", bit = 7 },
{ name = "27", port = "H", bit = 7 },
{ name = "28", port = "G", bit = 3 },
{ name = "29", port = "G", bit = 4 },
{ name = "35", port = "L", bit = 0 },
{ name = "36", port = "L", bit = 1 },
{ name = "37", port = "L", bit = 2 },
{ name = "38", port = "L", bit = 3 },
{ name = "39", port = "L", bit = 4 },
{ name = "40", port = "L", bit = 5 },
{ name = "41", port = "L", bit = 6 },
{ name = "42", port = "L", bit = 7 },
{ name = "43", port = "D", bit = 0 },
{ name = "44", port = "D", bit = 1 },
{ name = "45", port = "D", bit = 2 },
{ name = "46", port = "D", bit = 3 },
{ name = "47", port = "D", bit = 4 },
{ name = "48", port = "D", bit = 5 },
{ name = "49", port = "D", bit = 6 },
{ name = "50", port = "D", bit = 7 },
{ name = "51", port = "G", bit = 0 },
{ name = "52", port = "G", bit = 1 },
{ name = "53", port = "C", bit = 0 },
{ name = "54", port = "C", bit = 1 },
{ name = "55", port = "C", bit = 2 },
{ name = "56", port = "C", bit = 3 },
{ name = "57", port = "C", bit = 4 },
{ name = "58", port = "C", bit = 5 },
{ name = "59", port = "C", bit = 6 },
{ name = "60", port = "C", bit = 7 },
{ name = "63", port = "J", bit = 0 },
{ name = "64", port = "J", bit = 1 },
{ name = "65", port = "J", bit = 2 },
{ name = "66", port = "J", bit = 3 },
{ name = "67", port = "J", bit = 4 },
{ name = "68", port = "J", bit = 5 },
{ name = "69", port = "J", bit = 6 },
{ name = "70", port = "G", bit = 2 },
{ name = "71", port = "A", bit = 7 },
{ name = "72", port = "A", bit = 6 },
{ name = "73", port = "A", bit = 5 },
{ name = "74", port = "A", bit = 4 },
{ name = "75", port = "A", bit = 3 },
{ name = "76", port = "A", bit = 2 },
{ name = "77", port = "A", bit = 1 },
{ name = "78", port = "A", bit = 0 },
{ name = "79", port = "J", bit = 7 },
{ name = "82", port = "K", bit = 7 },
{ name = "83", port = "K", bit = 6 },
{ name = "84", port = "K", bit = 5 },
{ name = "85", port = "K", bit = 4 },
{ name = "86", port = "K", bit = 3 },
{ name = "87", port = "K", bit = 2 },
{ name = "88", port = "K", bit = 1 },
{ name = "89", port = "K", bit = 0 },
{ name = "90", port = "F", bit = 7 },
{ name = "91", port = "F", bit = 6 },
{ name = "92", port = "F", bit = 5 },
{ name = "93", port = "F", bit = 4 },
{ name = "94", port = "F", bit = 3 },
{ name = "95", port = "F", bit = 2 },
{ name = "96", port = "F", bit = 1 },
{ name = "97", port = "F", bit = 0 },
nickgammon
On the Mega aren't the last 16:
Code: [Select]
{ name = "A15", port = "K", bit = 7 },
{ name = "A14", port = "K", bit = 6 },
{ name = "A13", port = "K", bit = 5 },
{ name = "A12", port = "K", bit = 4 },
{ name = "A11", port = "K", bit = 3 },
{ name = "A10", port = "K", bit = 2 },
{ name = "A9", port = "K", bit = 1 },
{ name = "A8", port = "K", bit = 0 },
{ name = "A7", port = "F", bit = 7 },
{ name = "A6", port = "F", bit = 6 },
{ name = "A5", port = "F", bit = 5 },
{ name = "A4", port = "F", bit = 4 },
{ name = "A3", port = "F", bit = 3 },
{ name = "A2", port = "F", bit = 2 },
{ name = "A1", port = "F", bit = 1 },
{ name = "A0", port = "F", bit = 0 },
Also I don't seem to have D54 to D79 on my Mega. Are they brought out anywhere?
j514
Quote
I'm not sure.  What I did was copy + paste the pin layout from http://arduino.cc/en/Hacking/PinMapping2560 and ran it through a formatting routine.  I then trimmed the Vcc and Gnd pins from the output.
nickgammon
If you want to try this at home, Lua isn't hard to install.
Download source from:
http://www.lua.org/download.html
Pre-built binaries:
http://lua-users.org/wiki/LuaBinaries
Put the Lua source (above) into a file (eg. pinmappings.lua) and apply Lua to it:
Code: [Select]
lua pinmappings.lua
Or you could rework the code into C++. I was just feeling lazy when I did the Lua version.
