Topic: U8glib: Graphics Lib for LCDs and OLEDs (Read 242915 times) previous topic - next topic
mOskit
Hi. is this lib work with attiny85 and attiny84 over I2C?
Thanks
photoncatcher
U8glib 1.00 is available for download.
Note: The DFRobot ST7920 should be supported by the U8GLIB_ST7920_128X64 device,
but it has been reported that this is not working. Maybe someone from the Arduino
community is able to check this (I do not own this display).
Oliver
I have a 128x64 graphic ST7920 display clone that looks, walks, quacks and feels like a Robot. This one works with your updated library (> 1,000,000 x thanks) displaying temperature (DS18B20) and humidity (DHT11) see sketch, see picture of the setup
tashiwangdue
hello Arduino friends,
I have been looking for how to display Tibetan character on tft 2.4` mcufriend lcd for a week now...  I am not able to find any related articles to display Tibetan character at all.  can anyone help me how to make the display recognize Tibetan character Unicode encoding start with F00, and can display my language on any display
thank you in advance.
olikraus
u8glib does not support unicode, but it could be added to u8g2 (which does support unicode).
However u8g2 does not support tft RGB displays.
Shell I add Tibetan font to u8g2 (which is a monochrome graphics lib)?
Oliver
Oldass
#394
Feb 15, 2019, 07:31 pm Last Edit: Feb 15, 2019, 07:58 pm by Oldass
Please, I need description of internal u8glib font format.
I need to get one char from regular font (u8g_font_helvR08) to reduced one, like u8g_font_helvR08r. But I do not know the u8glib font structure.
Thank you.
olikraus
You can define the characters and/or remove the chars from the font source. Then use the modified font source file (BDF) and reconstruct the u8g font. Use the BDF sourcefile of the font and the bdf converter. Details are described here:
https://github.com/olikraus/u8glib/wiki/bdf2u8g
BDF font source: https://github.com/olikraus/u8glib/blob/master/tools/font/bdf/helvB08.bdf
Maybe also consider u8g2, which uses a compressed font format.
Oliver
Oldass
Qualcomm
Hi
Is it possible to use this library with the attiny85 digispark board and a st7920 LCD?
olikraus
Hi
U8g2 (the successor of U8glib) should work with attiny85 (only the U8x8 interface). ST7920 LCDs are supported with both libs.
Oliver
Qualcomm
Oliver
What is the u8x8 constructor for the st7920?
olikraus
lcd ym12864c i need library
Please start a new topic. Provide datasheet and controller name of your display.
Oliver
olikraus
Ups, i have to correct myself. ST7920 display are not supported by the U8x8 interface. Only U8g2 works with ST7920 due to the internal architecture of the controller.
Oliver
bobmixon
Greetings,
I am new to using this library; just started this week. Everything works as expected but I don't understand what the firstPage and nextPage functions do? Does the library or device support page buffering? Where can I find documentation on this?
Thank you,
Bob
olikraus
Greetings,
Thank you,
Bob
Description of the firstPage/nextPage funktion is here: https://github.com/olikraus/u8glib/wiki/tpictureloop
The idea is only to save RAM.
Also: Please consider to use U8g2, which still has the firstPage/nextPage loop but also inclused a  full buffer mode (for systems with sufficient RAM) .
Oliver
bobmixon
Oliver
Thank you for the documentation, makes complete sense. That's what I thought it was for as I've done it myself in other development efforts.
Thank you again!
