Topic: Your latest purchase (Read 573836 times) previous topic - next topic
TomGeorge
Do you mean that you paid money for a piece of plastic that you can glue an Uno and a Breadboard onto.
+1 to the marketing guys :)  :)
...R
It comes with screws and spacers and stick on feet.
$1.93 each.
Cost me more to drive around and buy the parts.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
wilykat
This acrylic UNO base and protoboard to fit, ebay.
Heh I just did the same thing a month ago
Missing MPU at the moment, the one I was using for breadboard mysteriously stopped working so I grabbed this one after uploading sketch.
TomGeorge
I have sorted my jumper wires out, so I have a container with short wires and the next size up that fit just right to the assembly.
Tom... :)
GoForSmoke
Could it have been because of a loose breadboard connection?
You can order a bootloaded 328P and some blanks to bootload yourself.
http://www.gammon.com.au/breadboard
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
wilykat
I have about 20 spares, I just need to get them out, have bootloader installed, and inserted back in the UNO board.
TomGeorge
#2060
Jul 03, 2018, 11:02 am Last Edit: Jul 03, 2018, 11:05 am by TomGeorge
I bought a couple of these ESP32 Devkit V1 boards.
Have got one operating in Cayenne, I've made a dashboard to observe.
This link will get you to it.
https://cayenne.mydevices.com/shared/5b3aeaa9c43373181503a6ed
Its just a basic;
Temperature, Humidity using DHT11
Pressure using a BMP085 that has bug that occurs when the environment gets to cold.
Room Light level is just an LDR.
The counter just counts the number of transmissions since turn-on.
The Packet Intervals is the time between transmission data bursts.
I have my own personal dashboard with some LED controls and servo control sliders on it.
I might put a LED control button on it, just to see who wants to play. :)
I have it here at home and I take it to work and plug it back in so the data will not always be continuous.
Tom... :)
Qdeathstar
Get some hall effect sensors and make yourself a  anemometer
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
TomGeorge
Yes, I could, I've got three identical deodorant spray can lids  for the cups.  :o :o
The ESP32 even  has a Hall Effect device fitted inside the wroom package.
Tom... :)
westfw
#2063
Aug 04, 2018, 09:39 am Last Edit: Aug 05, 2018, 02:58 am by Coding Badly
Arduino-like board with ZIF socket, AVR power that can be disconnected separately from the USB port, and easily disabled auto-reset.  It's mostly for testing Optiboot, especially WRT the issues that have been outstanding WRT reset-cause and MCUSR...  It's also got footprints for tiny84x and tiny1634, and only a couple of minor bugs.
(I really like those CH340E USB modules!)
(Oh yeah; it's also entirely Through-hole, and mostly single-sided.  The SMT footprints and "top layer other than things that could be jumpers" only got added after I realized that I was going to be lazy and send the board off to OSHPark instead of getting the LPKF working...)
Robin2
I like the Attiny1634. It is almost as good as an Atmega 328 but in a small SOIC package that is still big enough for hand-soldering - unlike the SMD versions of the 328.
However it seems to me the size value would be lost on a PCB designed for an DIP version of a 328 ?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
westfw
Quote
Yes.  In this case, the 1634 footprint is essentially ONLY useful for testing bootloaders...
larryd
#2066
Aug 05, 2018, 02:02 am Last Edit: Aug 05, 2018, 02:59 am by Coding Badly
Looks great!
Do you have a link where you got your driver for the CH340E.
Is that a self contained module i.e. CH340E and USB connector?  Link?
What's the yellow wire?
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
westfw
Quote
I've been getting them direct from http://www.wch.cn/products/CH340.html for my Mac.
Recent W10 tests seemed to show no driver needed. ?
Quote
Yep.  https://www.aliexpress.com/store/product/1PCS-CH340E-USB-to-TTL-Serial-Converter-5V-3-3V-Universal-Not-need-switching-Model-BTE17/213957_32821571106.html?spm=2114.12010608.0.0.4c137610DKxfYb
I mount the module "upside down" to provide some additional physical security for the microUSB connector.  The yellow wire just goes through the mounting holes and is soldered on the back...
(One thing "wrong" with this module is that there's no copper around the mounting holes, so you can't solder pins for physical support.)
larryd
#2068
Aug 05, 2018, 06:59 am Last Edit: Aug 05, 2018, 07:16 am by larryd
Thank you for the info.
If you can drill the holes to 3mm diameter, you could press fit 3.2mm brass inserts then solder the inserts to the foil around the enlarged holes.
However, looks like the holes are quite close to the board edges.
Maybe PCB eyelets could be riveted in the holes, solder to the eyelets.
No technical PMs.
3dprinter
#2069
Aug 10, 2018, 06:59 pm Last Edit: Aug 11, 2018, 11:40 pm by Coding Badly
Own designed PCB (my first, from a shop as opposed to home-CNC'ed) - attached
/Msquare
