Topic: Your latest purchase (Read 578448 times) previous topic - next topic
ChrisTenone
Nice. . . !
The problem with cars like this is the cord unplugs at 20 feet ;)
(snort)
What, I need to say something else too?
larryd
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Qdeathstar
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
larryd
Maybe load the back seat up with batteries and plug the cord into them.
That way you don't need to have a 100 km long extension cord.
No technical PMs.
ChrisTenone
'In all seriousness', what type battery does it have. I read somewhere that manufacturers are going back to nickel based batteries, instead of lithium, for cost reasons.
Qdeathstar
#2165
May 20, 2019, 01:46 pm Last Edit: May 20, 2019, 01:47 pm by Qdeathstar
Telsa uses lithium batteries. about 220mi range.  I don't think nickel based batteries are well suited for electric cars, especially when lithium batteries are going down in cost.  The charge rate for Nickel based batteries is slow.
Robin2
Just curious. Has anyone used an all-electric car in a North American winter?
For how many hours will the heater work if you get caught on a road blocked by a snowstorm?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
ChrisTenone
Granting that all-electric cars have different operating demands, Toyota finds nimh batteries a plus for inclement weather. Here's a short article about the different uses.
ChrisTenone
Henry_Best
I hear that those 100Km long extensions get very tangled at roundabouts.
Patrick_M
per inserire (lo sketch) il programma, dall'IDE clicca modifica, clicca copia per il forum poi vieni qui e incolla nel tuo post (ctrl+v) ;)
larryd
Here in Canada, ambient temperature can be -40 to +30 °C.
I have wondered how these cars can supply any range at all with winter heating and summer air conditioning.
No technical PMs.
Qdeathstar
the AC actually doesn't use that many miles.... but the heat will use a lot. They recommend using heated seats in lue of cabin heat... luckily the winters here aren't too bad.  And it still has a 200 mile range. I think they say you lose 5-10 miles of range per hr of heat...
I wouldn't take the tesla out for a road trip in the middle of winter, but i imagine if you were determined you could. They've got supercharger stations spread out every 100 miles or so, that take about an hour to give you a full charge.
I was able to drive from richmond to virginia beach which is about 105 miles with the AC full on and had 35 percent of batter remaining (50 miles). And i've learned of several tricks to increase range.
so i'd say you can reliably count on at least a 100 mile range worst case, which is enough to get to any supercharger station.
Tesla's are sweeeeeet.
sterretje
#2173
May 21, 2019, 05:30 am Last Edit: May 21, 2019, 05:35 am by sterretje
In 1994 I bought a BMW F650 Funduro; it was stolen last year :( Just over a month ago, her 16 year younger sister arrived.
She has the tough task living up to the expectations set by her older sister.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
Robin2
That's worrying. If the first charge station is out of order you won't have enough juice to get to the next one  :)
...R
