Topic: Your latest purchase (Read 578626 times) previous topic - next topic
Qdeathstar
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
raymw
Not my latest purchases, but my most recent ones vaguely interesting, one of these handy little usb current/voltage testers
https://www.amazon.co.uk/gp/product/B06XFZFZX6/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
and one of these component testers - saves squinting at faded resistance colours
https://www.ebay.co.uk/itm/All-in-1-component-tester-transistor-diode-capacitor-resistor-inductor-meteDLOI/153591547519?hash=item23c2c5067f:g:sJoAAOSwlkpcPsqs
or similar - based on the atmel 328.
groundFungus
#2222
Sep 05, 2019, 12:02 am Last Edit: Sep 05, 2019, 12:02 am by groundFungus
I bought one of those component testers (like in the link) a while back.  It is indeed very handy.  Especially for less than $10.00.
CrossRoads
#2223
Sep 05, 2019, 12:17 am Last Edit: Sep 05, 2019, 12:17 am by CrossRoads
I just bought a bottle of this cleaning concentrate.
Worked well to clean bugs off airplane wings. Wonder if it be effective to remove solder flux.]
TomGeorge
#2224
Sep 05, 2019, 12:38 am Last Edit: Sep 05, 2019, 12:39 am by TomGeorge
@raymw be  very careful you don't put the ribbon, where it is coming out of the display, under any stress.
I bought two of these and only one would work if the flex strip was positioned in a certain way.
The bend in the ribbon is more extreme than is shown in the picture.
For work I purchased the unit that came in a case.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
larryd
#2225
Sep 05, 2019, 02:32 am Last Edit: Sep 05, 2019, 02:32 am by larryd
Are there any bugs at 1000 feet?
Flying to Calgary?
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
raymw
Quote
Thanks for the warning. It probably needs putting in a case, if only to keep the bottom of the pcb away from any metal, bare wires, etc. (My Unos, I double sided taped an old credit card on the bottom! They are about the right size, and have rounded corners.)
ChrisTenone
I think it really ties the room together:
It helps me get 'in the zone', or maybe just zone out.
What, I need to say something else too?
larryd
No technical PMs.
ChrisTenone
I read about a random number generator somewhere, that used a lava lamp and a camera. The number was generated by the positions, shapes and sizes of the blobs. That would be cool. Wouldn't even need to be a camera - perhaps just put light detectors all over the glass surface.
westfw
ChrisTenone
Cool! Thanks for the link West.
(karmal added)
Coding Badly
#2232
Sep 20, 2019, 04:12 am Last Edit: Sep 20, 2019, 04:13 am by Coding Badly
larryd
50 PCS NDP6020P NDP6020 FSC MOSFET P-CH 20V 24A TO-220 NEW
https://www.ebay.ca/itm/381761716659
No technical PMs.
larryd
#2234
Sep 21, 2019, 05:06 am Last Edit: Sep 21, 2019, 05:07 am by larryd
KUUQA 50 Pack Cable Gland Waterproof Adjustable 3-16mm Cable Connectors PG7 PG9 PG11 PG13.5 PG16 PG19 Plastic Cable Gland Joints with Gaskets in PP Box
https://www.amazon.ca/gp/product/B07MBMSNG4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
No technical PMs.
