Topic: Your latest purchase (Read 578672 times) previous topic - next topic
larryd
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
raymw
Some MBR0520L to see if i can actually work with stuff that small. I ordered some from ebay, a week or two ago. I've no idea what they sent, nor did they, they wouldn't send the correct items as advertised, so I got my money back, and ordered via Amazon, and they are the correct diodes. 40 from a seller on Amazon was cheaper than via Farnel incl. postage. I only need a few, most will be dropped on the floor, I expect.
I've been with ebay for years, don't buy much, but recently I've had 3 out of six orders go bad, and I try to assess the quality of the supplier, not just their star ratings.
After wating for the stars to align and the wind to change, I tried soldering one of the diodes to the Nano pcb this morning. Not having the set-up that I had before, I managed to position the chip, using a scriber, but the liquid flux surface tension stuck the chip to the scriber point. My soldering iron tip is far, far too big, and I had to use a 10x jeweller's loupe to see what I was doing. After a  few attempts, however, I finally soldered it, and the Nano now seems to work via usb. Not financially, or otherwise worth the effort, but quite chuffed that I managed it - and I can rinse and repeat 39 more times, since I never lost any diodes...
wilykat
^^ if you had the right stuff already (magnifying glass workbench and fine tipper soldering iron), this would have been easy work.  And yes I would spend some time salvaging cheap Nanos by replacing bad diode.
Whandall
#2253
Oct 14, 2019, 06:46 pm Last Edit: Oct 14, 2019, 06:51 pm by Whandall
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
larryd
No technical PMs.
Qdeathstar
I just bought 250 plastic shot classes
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
groundFungus
I have heard that the shot class can cause memory problems.
Robin2
Gives me a ringing in my ears and an unpleasant burning smell :)
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Whandall
#2258
Oct 25, 2019, 11:16 pm Last Edit: Oct 25, 2019, 11:16 pm by Whandall
A metal sign I bought recently for 1€.
Qdeathstar
i use them for mixing epoxy and the like.
larryd
#2260
Oct 26, 2019, 04:15 am Last Edit: Oct 26, 2019, 04:16 am by larryd
Mixing epoxy in these cups, good idea.
Don't mix your epoxy with Vodka in these cups.
No technical PMs.
larryd
#2261
Oct 30, 2019, 10:00 pm Last Edit: Oct 30, 2019, 10:06 pm by larryd
For glueing plastic boxes etc.
This is a great tool for laying down a bead of solvent, DCM/Methylene Chloride.
https://www.flex-i-file.com/adhesives.php
Had to see if the commercial version was any good.
I make a similar tool but with a larger pipette and a #20 needle with a brass core wire.
https://www.amazon.ca/dp/B07TYTJPD6/?coliid=I2HBWR2L3A9P3L&colid=2IDMI904JXY0E&psc=1&ref_=lv_ov_lig_dp_it
No technical PMs.
Qdeathstar
#2262
Nov 14, 2019, 05:16 am Last Edit: Nov 14, 2019, 05:17 am by Qdeathstar
limited edition Ghost Seven Inches Of Satanic Panic poster.
larryd
No technical PMs.
sterretje
Wire-wrapping on a breadboard? I'm confused; isn't the diameter too thin for that?
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
