Topic: Temp, Humidity CO2 sensor and library. (Read 155127 times) previous topic - next topic
ajaved200
Dear Rob Tillart,
I tried to run this code http://www.co2meters.com/Documentation/AppNotes/AN128-%20Cozir_Arduino.pdf -
I tried to send the command " z\r\n" to get the co2 values but it didn't work for me so i removed the while condition and it started displaying co2 values
//while(buffer[ind-1] != 0x0A)
 if(mySerial.available())
 buffer[ind] = mySerial.read();
 ind++;
Now when I included the cozir.h file and tried to run this code (posted by @DirtGambit) nothing is displaying on serial monitor. I tried this arduino 1.0.3 as well.
#include <SoftwareSerial.h>
#include "cozir.h"
SoftwareSerial nss(3,2);
COZIR czr(nss);
 delay(3000);
 //czr.SetOperatingMode(CZR_POLLING);
 //czr.SetOperatingMode(CZR_STREAMING);
 float t = czr.Celsius();
 float f = czr.Fahrenheit();
 float h = czr.Humidity();
 int c = czr.CO2();
 int digi = czr.GetDigiFilter();
 Serial.print("Celcius : ");Serial.println(t);
 Serial.print("Fahrenheit : ");Serial.println(f);
 Serial.print("Humidity : ");Serial.println(h);
 Serial.print("CO2 : ");Serial.println(c);
 Serial.print("Digital Filter : ");Serial.println(digi);
robtillaart
#61
Oct 21, 2014, 06:16 pm Last Edit: Oct 21, 2014, 06:20 pm by robtillaart
I can't say as I do not have a sensor to verify problems, sorry :(
(reaction on post - 2 :)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
Try this echo script
Code: [Select]
  nss.begin(9600);
  delay(3000);
  if (nss.available())
    Serial.write(nss.read());
does it show anything?
Rob Tillaart
ajaved200
lemme try i ll let u know in a while
ajaved200
yes it displayed this
ÿÿ
I have connected sensor RX -> with Arduino pin#3
and sensor TX _> with pin #2
ajaved200
I added Serial.println("test");
it displayed this text on monitor...
strangely I have to re insert the wire connecting the sensor's RX with microcontroller pin#3 in order to display the text on the serial monitor.
robtillaart
ÿÿ
that means you have made a hard wired connection between the hardware Serial and the software serial.
The if statement in the code should do the copying but only if there is data available on the SW serial.
the yy indicates there is nothing to read()  (In fact it is ASCII char 255 or -1)
Rob Tillaart
robtillaart
Code: [Select]
  nss.begin(9600);
  delay(3000);
  nss.println("z")
  if (nss.available() > 0)
slightly different, added a "z" to tickle the sensor, and an explicit >0 test
can you try?
Rob Tillaart
ajaved200
I tried this as well.. still showing "ÿ"
Code: [Select]
  nss.begin(9600);
  delay(3000);
  nss.println("z")
can you try?
robtillaart
Which version of the IDE are you using?
Which board? UNO/MEGA?
The COZIR is connected to pin 2 and 3 I assumed....Right?
Rob Tillaart
ajaved200
I am using audrino UNO and yess cozir is connected with pin 2 and pin 3
ajaved200
i tried with audrino v 1.0.5 and v 1.0.3 as well
robtillaart
I'm out of options now, as said before I do not have such sensor to replicate your project, sorry
Rob Tillaart
ajaved200
I can understand. Thanks a lot for your help.
roder
I posted the Cozir library to github for convenience (and a project that I was working on).
https://github.com/roder/cozir
