Topic: upload blink sketch to Arduino-Mini (04) unsuccesfull/invalid device signature (Read 7378 times) previous topic - next topic
somedutchguy
I try to upload the blink example to my brand new Arduino Mini-04, but to no avail.
Avrdude says 'invalid device signature' and that the option -F should be used.
How can you set that option?
I'm pretty sure the communication itself is OK, because I use the verbose output during upload and I see replies coming from the mini (see below).
Related to this: which boot loader is supposed to be installed for the mini-04?
Any help very much appreciated!
Verbose output during upload from avrdude
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [03]
avrdude: Recv: . [10]
avrdude: Send: A [41] . [81]   [20]
avrdude: Send: A [41] . [82]   [20]
avrdude: Send: A [41] . [98]   [20]
         Hardware Version: 3
         Firmware Version: 3.3
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [00]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.05s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
johnwasser
When talking to the bootlaoder it is the bootloader that supplies the device signature.  For some reason the bootloader on your Arduino Mini-04 is returning 00 00 00. Are you selecting the board "Arduino Mini w/ ATmega328"?
Perhaps you got one with a bad bootloader.  You could try re-flashing the bootloader.  You will need an ISP or an arduino on which you can run ArduinoISP.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
somedutchguy
Thanks John for your advice.
Indeed, I forgot to tell, I selected the Arduino Mini with ATMega 328.
Yes, I was thinking of the boot loader. Unfortunately I do not yet have an ISP or 2nd Arduino :-(
Henk
mellis
In Arduino 1.0, try changing:
mini328.upload.protocol=stk500
to:
mini328.upload.protocol=arduino
in the boards.txt file.  Does that fix the problem?
somedutchguy
Hi Mellis, thanks very much, that did the trick!
I just wonder if it should be noted more prominently on the arduino site (the getting started section for the mini-328)? Anyway, thanks a lot !
