Topic: Arduino Serial Comm Issues (Read 4166 times) previous topic - next topic
SuperSteve
Having issues returning output to a terminal emulator (puTTY) from a Arduino Uno, we are trying to set up a oil pumping and monitoring system. It's returning output when running through the Arduino IDE however when running through puTTY no output is generated and the program seems to not be running. When printing any data in the main loop function it seems to print fine to both puTTY and Arduino IDE.
Very confusing  :~ Any Ideas?
Code: [Select]
int serialInput[9];
int a = 0;
int tempInt1, tempInt2, tempInt3, tempInt4, tempInt5, tempInt6, tempInt7, tempInt8, tempInt9;
int litres, pulses, flowPIN, solPIN, AwesPIN;
boolean pumping;
int buttonState = 0;
int lastButtonState = 1;
int buttonPushCounter;
float output = 0.000;
unsigned long time;
boolean setTimer = false;
  //Set up Serial Session at 9600 Baud
void loop () {
  if ( Serial.available() > 0) {
    setTimer = true;
    while(a < 9)
    serialInput[a] = Serial.read();
    a=a+1;
    delay(10);
    a = 0;
    tempInt1 = serialInput[0] - 48;
    tempInt2 = serialInput[1] - 48;
    tempInt3 = serialInput[2] - 48;
    tempInt4 = serialInput[3] - 48;
    tempInt5 = serialInput[4] - 48;
    tempInt6 = serialInput[5] - 48;
    tempInt7 = serialInput[6] - 48;
    tempInt8 = serialInput[7] - 48;
    tempInt9 = serialInput[8] - 48;
    litres = (tempInt1 * 10) + tempInt2;
    pulses = (tempInt3 * 100) + (tempInt4 * 10) + tempInt5;
    flowPIN = (tempInt6 * 10) + tempInt7;
    solPIN = (tempInt8 * 10) + tempInt9;
    pinMode(flowPIN, OUTPUT);
    if (pumping == false) {
      AwesPIN = solPIN;
      pinMode(AwesPIN, OUTPUT);
    if (litres == 0 && pulses == 0 && flowPIN == 0 && solPIN == 0) {
     digitalWrite(AwesPIN, LOW);
     pumping = false;
   if (solPIN > 0) {
    pinMode(solPIN, OUTPUT);
    digitalWrite(solPIN, HIGH);
    pumping = true;
    buttonPushCounter = 0;
  if ((millis() - time) == 600000) {
  pumping = false;
  Serial.println("Timeout");
  if (pumping == true) {
    if (setTimer == true) {
      time = millis();
      setTimer = false;
   buttonState = digitalRead(flowPIN);
      if (buttonState != lastButtonState) {
        if (buttonState == HIGH) {
          buttonPushCounter++;
           output = (float)buttonPushCounter/(float)pulses;
           Serial.println(output);
           delay(100);
Serial.println(buttonState);
Serial.println(lastButtonState);
Serial.println("--");
       lastButtonState = buttonState;
  if (buttonPushCounter == litres * pulses) {
   pumping = false;
   digitalWrite(solPIN, LOW);
PaulS
Quote
I doubt that. The Arduino may be writing to the Serial Monitor, but that is a separate application from the IDE.
Code: [Select]
Wouldn't an array make more sense?
Code: [Select]
    setTimer = true;
    while(a < 9)
    a=a+1;
    delay(10);
If there is one character available to read, read all 9 of them, hoping that the others show up before the read is attempted. This is a recipe for disaster. Any robust communication mechanism will use, at a minimum start- and end-of-packet markers, so you KNOW when to start reading AND when to stop.
Code: [Select]
Wrong!!!!
    tempInt1 = serialInput[0] - '0';
Code: [Select]
Why are you setting the pin mode in loop()? Are you using the pin for both input and output?
Code: [Select]
           delay(100);
Each { belongs on it's own line. The Tools + Auto Format menu option would properly indent all of your code, to make it more readable.
Quote
You don't have any print statements in setup(), and you don't have any other functions, so I fail to see what the problem is.
mromani
Quote
Quote
I think by "main loop function" he meant "loop() function". There are print(ln) statements in there.
PaulS
Quote
There are, but he says those work, and it is the others that don't. There being no others, I don't understand what doesn't work.
mromani
Code: [Select]
It's very difficul that you catch that exact value. In other words, use >=, not ==.
SuperSteve
Hey, Thanks for the feedback. I've made some changes to my code but the problem is still present.
Quote
This is because the Solenoid PIN and the Flow Meter PIN are defined via Serial Input
Code: [Select]
int serialInput[9];
int a = 0;
int litres, pulses, flowPIN, solPIN, flowPIN2;
boolean pumping;
unsigned long time;
void loop () {
    setTimer = true;
    while(a < 9)
      a=a+1;
      delay(10);
    a = 0;
    serialInput[0] = serialInput[0] - '0';
    serialInput[1] = serialInput[1] - '0';
    serialInput[2] = serialInput[2] - '0';
    serialInput[3] = serialInput[3] - '0';
    serialInput[4] = serialInput[4] - '0';
    serialInput[5] = serialInput[5] - '0';
    serialInput[6] = serialInput[6] - '0';
    serialInput[7] = serialInput[7] - '0';
    serialInput[8] = serialInput[8] - '0';
    litres = (serialInput[0] * 10) + serialInput[1];
    pulses = (serialInput[2] * 100) + (serialInput[3] * 10) + serialInput[4];
    flowPIN = (serialInput[5] * 10) + serialInput[6];
    solPIN = (serialInput[7] * 10) + serialInput[8];
    Serial.print("Litres = ");
    Serial.println(litres);
    Serial.print("Pulses = ");
    Serial.println(pulses);
    Serial.print("Flow Meter PIN = ");
    Serial.println(flowPIN);
    Serial.print("Solenoid PIN = ");
    Serial.println(solPIN);
    Serial.println("Litres Pumped:");
      flowPIN2 = solPIN;
      pinMode(flowPIN2, OUTPUT);
      digitalWrite(flowPIN2, LOW);
      pumping = false;
    if (solPIN > 0) {
      pumping = true;
  if ((millis() - time) >= 600000) {
    pumping = false;
      time = millis();
      setTimer = false;
    pumping = false;
Output from Arduino Serial Monitor, Which is Correct
Code: [Select]
Litres = 5
Pulses = 5
Flow Meter PIN = 2
Solenoid PIN = 3
Litres Pumped:
0.20
0.40
0.60
0.80
1.00
1.20
1.40
1.60
1.80
2.00
2.20
2.40
2.60
2.80
3.00
3.20
3.40
3.60
3.80
4.00
4.20
4.40
4.60
4.80
5.00
Output from PuTTY
Code: [Select]
Litres = 2
Pulses = 5
Flow Meter PIN = 2
Solenoid PIN = 3
Litres Pumped:
Litres = -399
Pulses = -5439
Flow Meter PIN = -539
Solenoid PIN = -539
Litres Pumped:
-0.00
PaulS
Quote
Quote
Output from PuTTY
which is all hosed up.
So, how is this an Arduino problem? Clearly, the Arduino is sending data correctly. The PuTTY application, on the other hand, is not processing it correctly. Looks like a configuration issue with PuTTY to me.
PaulS
Quote
The pin to set HIGH or LOW might be coming from the serial port, but the fact that certain pins have hardware associated with them doesn't change, while the Arduino is running, does it?
The pin mode should be set in setup(). The setting of the pin HIGH or LOW should be done in loop(), based on the serial data.
mromani
Quote
Quote
Output from PuTTY
A screenshot of putty configuration might help diagnose the problem. Maybe the option "Implicit CR on every LF" under "Terminal" has something to do with those blank lines in the output ?
PaulS
Hey mromani - Congrat's on the promotion to deity!
mromani
Huh ?
Ah, yes, I suppose it's because of the 500th post. Thanks :-)
dxw00d
#11
Feb 15, 2012, 03:49 pm Last Edit: Feb 15, 2012, 04:37 pm by dxw00d Reason: 1
Personally, I think it's a daft title, particularly as my partner thinks it's funny. Presumably, we're stuck with it until 1000 posts.
mromani
Are you saying I should start a stealth spam campaign to find out what's after god ? :-P
PaulS
Quote
No need. Edison comes next.  8)
mromani
(self-censored comment to stop this way too far OT)
:smiley-zipper:
