Topic: Arduino Serial Comm Issues (Read 4162 times) previous topic - next topic
SuperSteve
Quote
The pin to set HIGH or LOW might be coming from the serial port, but the fact that certain pins have hardware associated with them doesn't change, while the Arduino is running, does it?
The pin mode should be set in setup(). The setting of the pin HIGH or LOW should be done in loop(), based on the serial data.
Since we are going to be using the device on different configurations we are passing what Pin's are designated to Input and Output via the Serial.
I think I've resolved the problem. Although the Serial Input is 9 digits I've increased the array it's reading into to 10 fields and it seems to be working now, is there any reason for this???
paulypopex
are you sending a carriage return?
PaulS
Code: [Select]
     a=a+1;
Have you ever considered that the language used to program the Arduino is not called C=C+1?
mromani
Code: [Select]
     a=a+1;
:D :D
