Topic: Mini Pro 5v 16Mhz and NewSoftSerial Fail **SOLVED** (Read 685 times) previous topic - next topic
chaost
Feb 17, 2012, 04:07 pm Last Edit: Feb 17, 2012, 06:18 pm by chaost Reason: 1
Hi Guys,
I have a GSM chip working with an Arduino Uno using NewSoftSerial to communicate on pins 2 and 3. All perfect.
However, when I transfer the exact script and pin configuration to the Mini Pro it *seems* that longer character strings are not being sent to the GSM chip completely.
For instance:
This works : "AT+CGACT=1,1"
This works : "AT+CNUM"
This fails : "AT+CGDCONT=1,\"IP\",\"payandgo.o2.co.uk\""
This fails : "AT+SDATACONF=1,\"TCP\",\"xx.xx.xxx.xx\",5124"
String length seems to be factor here. And, as I said, the same script works ok on an Uno.
I have done some digging around and have found various references to NewSoftSerial not working with the 3.3V 8Mhz Pro Uno. From what i can tell, it should work with the 5v variant because it runs at 16Mhz.
To completely eliminate the possibility of a faulty / mislabelled product, I have tried two different 5v Pro Mini's and tested the output voltage from the pins - both are defo 5v and i presume this means they should also both be 16Mhz (is there a way to test clock speed btw?)
Has anyone come across this before? Is there something obvious I am missing?
Many thanks in advance for any tips!
chaost
Update:
Maybe this isn't a NewSoftSerial issue.
I just tested using Tx0 and Rx1 (Serial) and didn't use NewSoftSerial.
Worked fine on the UNO but not on the Pro Mini.
lol - after everything I have been through on this project, i can't believe i'm getting stumped at the very FINAL hurdle! Agh!
chaost
I have solved the issue...
Whilst going through every possible influencing factor i reduced the input voltage from 11.5V on RAW to 10V. The script then ran flawlessly every time (following about 1,000 fails!)
The 11.5V was pretty much constant and i didn't see it spike above the documented 12v maximum. So maybe the boards regulator was interfering with the operation whist working hard  :P
Anyway - documented in case anybody else hits this issue.
