Topic: Cannot Open arduino_test.pde on MAC OSX 10.5.8 (Read 5724 times) previous topic - next topic
Jim_Durbin
Mar 03, 2012, 10:24 pm Last Edit: Mar 13, 2012, 02:56 pm by Jim@Austin Reason: 1
I downloaded the test sketch but keep getting the message from my MAC OS X 10.5.8 that "there is no default application specified to open the document "arduino_test.pde""   What is the application needed, and how do I find it?  What am I doing wrong?
madworm
Just open the IDE. Then use "file-->open..." and so forth.
Jim_Durbin
I hit file>open and that's when the message appears, stating that there is no default application to open it.
cmiyc
Did you already download the Arduino IDE?
1.0 switched to using .ino as the file extension.  So PDE may not be associated with the Arduino IDE.  The suggestion to use "File -> Open" was from inside of the Arduino IDE and not Finder.  Try opening the PDE from inside the Arduino IDE or right-click on the .PDE file and select "Open With...".
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Jim_Durbin
#4
Mar 12, 2012, 05:27 pm Last Edit: Mar 12, 2012, 05:32 pm by Jim@Austin Reason: 1
I opened the Arduino IDE and tried to open arduino_test.pde within the IDE, but when I clicked to open, the message was that there is no default application to open arduino_test.pde.  When I right clicked on arduino_test.pde, I clicked onto "open with".  I was given the option to choose an application.  When I clicked on Arduino as the application, I could not go any further.  The only option was to cancel.  How can I designate the application?
kd7eir
#5
Mar 12, 2012, 10:54 pm Last Edit: Mar 12, 2012, 10:58 pm by kd7eir Reason: 1
The only time that I have seen OS X only show the CANCEL option when choosing what program to open a file with was when a non-executable file was selected.
Make sure that you are clicking on the arduino application and not a zip or dmg file.
cmiyc
You can attach files to posts.  Attach the pde to a post so others can try opening it.  Perhaps the file is corrupted.
Jim_Durbin
Here is the application sequence:
/Applications/Arduino/Arduino/arduino_test/arduino_test.pde
cmiyc
That doesn't make any sense.
Please attach the pde to post.
Jim_Durbin
#9
Mar 13, 2012, 04:02 am Last Edit: Mar 13, 2012, 02:53 pm by Jim@Austin Reason: 1
Here is the file
Thanks for your help.
cmiyc
I don't know why you can't open it.  I was able to open it in the Arduino IDE versions 0022 and 1.0, on Lion.
Here's the code you can copy / paste into a new sketch:
Code: [Select]
const int LED = 13;          // LED to digital pin 13 (D13)
const int POT = A0;          // pot to analog pin 0 (A0)
int potValue = 0;            // variable for pot value
  // initialize digital pin 13 as an output
  pinMode(LED, OUTPUT);
  potValue = analogRead(POT);  // read pot value
  digitalWrite(LED, HIGH);     // turn LED on
  delay(potValue);             // wait for value (milliseconds)
  digitalWrite(LED, LOW);      // turn LED off
nickgammon
#11
Mar 13, 2012, 06:17 am Last Edit: Mar 13, 2012, 06:20 am by Nick Gammon Reason: 1
What is the file arduino_test.pde doing inside the application? What have you done?
The test file should be in the documents folder. I don't know how it ended up inside /Applications/Arduino/.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
And can you amend the topic heading please? "Pardon my ignorance" doesn't encourage people to open the thread. Something like "Cannot open .pde file on Mac OS/X 10.5.8" would be more appropriate.
kd7eir
Worked fine on OS X Lion using 1.0 for me as well.
Jim_Durbin
