Topic: createChar() tutorial no longer works due to lcd.write (Read 6107 times) previous topic - next topic
hellonearthis
Just been working with custom LCD characters and found that the createChar() tutorial is out of date with version 1.0 of the IDE.
http://arduino.cc/en/Reference/LiquidCrystalCreateChar
The LCD.write(0); no longer works and can be replaced with LCD.print((char)0);
Working example:
Code: [Select]
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
byte smiley[8] = {
  B00000,
  B10001,
  B00000,
  B00000,
  B10001,
  B01110,
  B00000,
  lcd.createChar(0, smiley);
  lcd.begin(16, 2);
//  lcd.write(0); no longer works
  lcd.print((char)0);
void loop() {}
gcm2
Thank you mucho! - I just ran into this last night for the first time, and gave up trying to use write(0) since it would not compile. print((char),0) works, and the rest of my "normal" write(x)'s are fine.
gcm2
hellonearthis
DWRIGHT02
thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you
i spent a long time trying to solve this issue. thank you!!!!
