Topic: Zero crossing detection (Read 17477 times) previous topic - next topic
taurian
Mar 11, 2012, 07:30 pm Last Edit: Mar 11, 2012, 07:31 pm by Coding Badly Reason: 1
hello
I am through an electronic circuit to detect the I zero crossing it enters the pin enables the interruption arduino and to calculate the period of the input signal.
this and the code I'm using ....
Code: [Select]
int digitalPin=2;
float pulseHigh,stopTime,startTime,pulseLow,perio;
void setup(){
  pinMode(digitalPin, INPUT);
   attachInterrupt(0, periodo,FALLING);
void loop(){
void periodo(){
  detachInterrupt(0);
 if(digitalRead((2)==HIGH)){
 startTime=micros();
   pulseHigh=startTime-stopTime;
 if(digitalRead((2)==LOW)){
   startTime=micros();
   pulseLow=stopTime-startTime;
 perio=pulseHigh+pulseLow;
 Serial.println('Periodo');
 Serial.println(pulseHigh,BIN);
Thanks Gil
Moderator edit: [code] [/code] tags added.
Grumpy_Mike
You can't use serial print from inside an interrupt routine.
taurian
But as I do as a void function does not return?
Thanks Gil
Grumpy_Mike
A void function is just a function that returns no values, this has nothing to do with your problem which is that you are using print statements inside an interrupt.
taurian
yes you are right I have to do seriaprint outside the function.
Techone
Quote
I am just curious. What is the schematic ? Can you post it ? And what is the expect frequency going into the interrupt pulse ?
I did a code to measure the time on and off of a AC voltage from the plug of a home.  I use pulseIn(). A little calculation there, and I show the frequency, duty cycle, time on and time off. No interrupt. The Ardiuno is fast enough to use pulseIn(). An interrupt will work, but it as to be very short, like for example :
Code: [Select]
void myinterrupt()
  state = HIGH;
And in your main code, you simply check that HIGH using a while() loop or if() or do { } while() loop.
el_supremo
You should not call detachInterrupt in the interrupt routine. When you do that it means that subsequent interrupts will not call periodo again.
Pete
Don't send me technical questions via Private Message.
nickgammon
Code: [Select]
void periodo(){
   detachInterrupt(0);
  if(digitalRead((2)==HIGH)){    //  <---- well this will never happen
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
taurian
Quote
Hello
I tried to do it your way whatever. I have the circuit in proteus I've put it here.
int pin = 7;
int pin1 = 6;
unsigned long duration, pulseHigh, pulseLow,fre;
  pinMode(pin, INPUT);
  pinMode(pin1, INPUT);
  //Serial.println('duration');
  pulseHigh = pulseIn(pin, HIGH);
  pulseLow = pulseIn(pin1,LOW);
  duration= pulseHigh+pulseLow;
  fre=1/duration;
  Serial.println(fre);
thank Gil
taurian
Quote
void periodo(){
   detachInterrupt(0);
I want to calculate a time period then I will release the microcontroller to do other operations, and only when done and recalculates the period.
thank Gil
Grumpy_Mike
Quote
Link??
Please use the # icon when posting code not the quote icon next to it.
taurian
ok thanks for the info
Thanks Gil :)
Techone
@taurian
What is the frequency of the pulse being measured ?
The example code being show by you will work. The trick is, to sample the pulse a few times, average it and than you display and do other things, and come back you take samples again.   The interrupt method is OK, but you have to activate the interrupt, sample the pulse, de-activate the interrupt, and calculate, display, whatever you have to do and repeat.
taurian
Quote
The frequency that will work will be 60Hz to 50Hz
with the interruption is in order so that detects a transition by zero I start taking samples, but I have a problem if the frequency changes. always had to read the frequency ..
I do not know how?
Thanks Gil
raxz
#14
Mar 12, 2012, 08:39 pm Last Edit: Mar 12, 2012, 08:40 pm by Ragnar Reason: 1
Is Your zero crossing detection schematic working?
I got my dimmer working.
I'm using Arduino Mega 1280.
Here is my code, hope You understand:
Code: [Select]
volatile int counterValue;
int requestValue;
 attachInterrupt(0, resetCounter, CHANGE);
 cli();                      //Disable global interrupts
 TCCR3A = 0;                 //Set register to 0
 TCCR3B = 0;                 //Set register to 0
 OCR3A = 640;                //Compare match register to get desired timer count (50Hz mains)
 TCCR3B |= (1 << WGM12);     //Turn on CTC mode
 TIMSK3 |= (1 << OCIE3A);    //Enable timer compare interrupt
 TCCR3B |= (1 << CS10);      //Start timer
 sei();                      //Enable global interrupts
 pinMode(7, OUTPUT);
ISR(TIMER3_COMPA_vect) {
 counterValue++;
 counterValue &= 0xff;
 if (counterValue==requestValue) {
   digitalWrite(7, HIGH);
   digitalWrite(7, LOW);
void resetCounter()
 counterValue=0;
void loop(){
 requestValue=map(analogRead(0), 0, 1023, 0, 255);
