Topic: Zero crossing detection (Read 17651 times) previous topic - next topic
taurian
Code: [Select]
#include <Timerthree.h>
#include <Timerone.h>
volatile int counterValue;
int requestValue;
  attachInterrupt(0, resetCounter, CHANGE);
  cli();                      //Disable global interrupts
  TCCR3A = 0;                 //Set register to 0
  TCCR3B = 0;                 //Set register to 0
  OCR3A = 640;                //Compare match register to get desired timer count (50Hz mains)
  TCCR3B |= (1 << WGM12);     //Turn on CTC mode
  TIMSK3 |= (1 << OCIE3A);    //Enable timer compare interrupt
  TCCR3B |= (1 << CS10);      //Start timer
  sei();                      //Enable global interrupts
  pinMode(7, OUTPUT);
ISR(TIMER3_COMPA_vect) {
  counterValue++;
  counterValue &= 0xff;
  if (counterValue==requestValue) {
    digitalWrite(7, HIGH);
    digitalWrite(7, LOW);
void resetCounter()
  counterValue=0;
void loop(){
  requestValue=map(analogRead(0), 0, 1023, 0, 255);
I already have the libraries when compiling the code but got an error says that the variables are not declared...
Example: sketch_mar13a: 11: error: 'OCR3A' was not declared in this scope
sketch_mar13a: 13: error: 'TIMSK3' was not declared in this scope
sketch_mar13a: 13: error: 'OCIE3A' was not declared in this scope
thank you
Techone
@taurian
Thank for the schematic. Did you connect the ground to the battery ?   Is like :  pos 9 neg   ---- GND --- pos 9 neg
The gnd is the middle of the battery connection. Did you connected it there ? That is the right place. The schematic look "fine", but I just wonder...
raxz
I'm not using any libraries.
Following code compiles ok.
Binary sketch size: 3188 bytes (of a 126976 byte maximum)
Code: [Select]
int requestValue;
  pinMode(7, OUTPUT);
  counterValue++;
void resetCounter()
  counterValue=0;
void loop(){
taurian
Quote
Thank you now I'm trying to adapt the code to my project after any doubt I'll give news
thank:)
taurian
@techone
I have not connected to any battery my input signal going to pull the generator functions ..
but did not realize your question
thank
Techone
Your circuit is using op-amps. It need a dual power line ( + line, - line ) and the gnd is the mid point of the batteries connection. And the gnd has to be connected with the gnd to work properly.
I hope you understand.
taurian
The battery I used to say to this is to feed the polarization of the m-amp.
  The polarization and I'm using 5v and 0v and I use the v 5 the arduino.
Thank Techone
taurian
This and my code to read an analog value but the result is not good.
thank
Code: [Select]
#include <TimerOne.h>
int ledPin =2;    // LED connected to digital pin 13
int analogPin=3;
float a;
void setup()   {
  pinMode(ledPin,INPUT);
  pinMode(13, OUTPUT);
  Timer1.initialize(131000);
  attachInterrupt(0,periodo,RISING);
// the loop() method runs over and over again,
// as long as the Arduino has power
  a=analogRead(analogPin);
  Serial.println(a);
void periodo()
  digitalWrite( 13, digitalRead( 13 ) ^ 1 );
raxz
What is not good? What You expect? What You get?
taurian
I wanted to see the values ??vary depending on the analog input signal and this does not happen that the values ??are repeated.
thank
