Topic: TinyGPS library and GPS accuracy - decimal place truncation (Read 3521 times) previous topic - next topic
alfurey
Mar 14, 2012, 04:18 pm Last Edit: Mar 14, 2012, 04:34 pm by al_f Reason: 1
Hi all,
have been using the tiny gps library and  a venus GPS (http://www.sparkfun.com/products/11058) . Got it reading the GPS today and parsing the data using the library. Thing is the data comes from the GPS latitude and longitude minutes to 6 decimal places but the library only returns 5.
The 6th dp wanders a little but is still useful. There is plenty of room in the long int that stores the lat and long - full data for each of latitude and longituse will be 8 numbers, i.e. 2 numbers for minutes and 6 decimal places.
No idea why you would truncate data like this!
Have looked in the library and being cpp is a little opaque for me who only generally uses C and matlab. It looks like the offending function is:
Code: [Select]
unsigned long TinyGPS::parse_degrees()
 char *p;
 unsigned long left = gpsatol(_term);
 unsigned long tenk_minutes = (left % 100UL) * 10000UL;
 for (p=_term; gpsisdigit(*p); ++p);
 if (*p == '.')
   unsigned long mult = 1000;
   while (gpsisdigit(*++p))
     tenk_minutes += mult * (*p - '0');
     mult /= 10;
 return (left / 100) * 100000 + tenk_minutes / 6;
Any ideas how to tweak this so that i can retain the last dp that i can see is there on the raw stream?
The basic code to get the data is below.
btw there is a method to get the data out as a float but it is still truncated.
Code: [Select]
#include <TinyGPS.h>
#include <NewSoftSerial.h>
TinyGPS gps;
#define RXPIN 10
#define TXPIN 11
NewSoftSerial nss(RXPIN, TXPIN);
long lat, lon;
unsigned long age, time, date, speed, course;
unsigned long chars;
unsigned short sentences, failed_checksum;
bool newdata;
 Serial.begin(57600); // Radio serial
   // set the data rate for the SoftwareSerial port
 nss.begin(38400);
 // prints title with ending line break
 while (nss.available())
   int c = nss.read();
   gps.encode(c);
 gps.get_position(&lat, &lon, NULL);
   Serial.print("Latitude:  "); Serial.println(lat);
   Serial.print("Longitude:  "); Serial.println(lon);
 delay(10);
//__________________________________________________
static bool feedgps()
   if (gps.encode(nss.read()))
     return true;
 return false;
hhermsen
Found the answer in the reply of 'Michael Shimniok (Bot Thoughts)' on the Arduiniana TinyGPS page which referrers to a fix at http://pastebin.com/NcnR96T4.
