Topic: Reprograming the Mega16U2 (Read 10972 times) previous topic - next topic
Tumbleweed
Mar 15, 2012, 01:56 am Last Edit: Mar 15, 2012, 02:32 am by Tumbleweed Reason: 1
I need to try reprogramming the firmware for the Usb chip on my Arduino, if that doesn't work I am going to try to change it, need the smd practice. Then it will need programming.
Will a TinyISP work for hardware?
In Windows will Avrdude work thru the Arduino IDE like for a 328, or do I need WinAVR also.
I found the latest firmware, but it is a Hex file (I think). Looks like a bunch of garbage numbers, had to open and then cut and paste,
no download provided. I'll keep trying to find the right file.
I have about $5 in repairing this board including the Mega16U2, so I don't want to spend more than necessary, but everyone needs an ICSP programmer, right?
Any info or links to such problems would be greatly appreciated.
Thanks
TomJ
Edit,
If I pulled the Atmega16U2 completely out of the board could I hook up the RX, TX, Grnd, Power, and reset pins from my FTDI friend to program the 328, just like a breadboard setup or Boarduino?
Just wonderin'.
Thanks again
TomJ
Einstein once said you don't really understand anything until you can explain it to your Grandmother
nickgammon
#1
Mar 15, 2012, 02:51 am Last Edit: Mar 15, 2012, 07:33 pm by Nick Gammon Reason: 1
This is what I found so far (on a Mac - on Windows the paths will be a bit different):
I have a Uno Rev 3, so the Atmega16U2 has a 6-pin ISP breakout plug-thing on it. So that's a start.
http://www.gammon.com.au/uno
I plugged my USBtinyISP into this header, and tried this:
Code: [Select]
avrdude -c usbtiny -v -p m328p
Got this response:
Code: [Select]
avrdude: Device signature = 0x1e9489
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
So, wrong signature, which I expected. So I needed to find the chip code for the signature 0x1e 0x94 0x89. That was not in my avrdude.conf file. You can test by trying this:
Code: [Select]
avrdude -c usbtiny -v -p m16u2
I got:
Code: [Select]
avrdude: AVR Part "m16u2" not found.
A bit of a Google search, and I turned up this patch:
http://www.nmj.sumomo.ne.jp/suz-avr/USB162/avrdude-5.8-confu2.patch
Who knows if it is the right one?
However inside that file was this:
Code: [Select]
+# ATMEGA16U2
+part
+    id               = "m16u2";
+    desc             = "ATMEGA16U2";
+    has_jtag         = no;
+    has_debugwire    = yes;
+    signature        = 0x1e 0x94 0x89;
(Note: that isn't the complete file - you have to download it).
Looks like the right signature, and the right part number.
I found my avrdude.conf file here:
Code: [Select]
/usr/local/CrossPack-AVR-20100115/etc/avrdude.conf
Changing to the directory /usr/local/CrossPack-AVR-20100115/etc/ I tried to patch it, as follows:
Code: [Select]
cp avrdude.conf avrdude.conf.orig  # make backup!!!
patch < avrdude-5.8-confu2.patch  # patch file
That gave this:
Code: [Select]
can't find file to patch at input line 4
Perhaps you should have used the -p or --strip option?
The text leading up to this was:
|diff -ru avrdude-5.8/avrdude.conf.in avrdude-5.8-wk/avrdude.conf.in
|--- avrdude-5.8/avrdude.conf.in 2010-12-06 13:47:47.000000000 +0900
|+++ avrdude-5.8-wk/avrdude.conf.in 2010-12-06 13:49:52.000000000 +0900
File to patch:
I replied: avrdude.conf
Got this:
Code: [Select]
File to patch: avrdude.conf
patching file avrdude.conf
Hunk #1 succeeded at 12785 (offset -383 lines).
Tried to read the chip again:
Code: [Select]
Got:
Code: [Select]
Reading | ################################################## | 100% 0.01s
avrdude: safemode: lfuse reads as EF
avrdude: safemode: hfuse reads as D9
avrdude: safemode: efuse reads as F4
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
So far so good. It recognized the chip and gave me the fuses.
Now to read the existing flash:
Code: [Select]
avrdude -c usbtiny -p m16u2 -U flash:r:usb_chip.hex:i
Success! ...
Code: [Select]
avrdude: AVR device initialized and ready to accept instructions
avrdude: reading flash memory:
Reading | ################################################## | 100% 30.30s
avrdude: writing output file "usb_chip.hex"
Convert to machine-readable:
Code: [Select]
avr-objdump -j .sec1 -d -m avr3 usb_chip.hex > usb_chip.asm
Edit that:
Code: [Select]
usb_chip.hex:     file format ihex
Disassembly of section .sec1:
00000000 <.sec1>:
      0: 90 c0       rjmp .+288     ;  0x122
      2: 00 00       nop
      4: a9 c0       rjmp .+338     ;  0x158
      6: 00 00       nop
      8: a7 c0       rjmp .+334     ;  0x158
    122: 11 24       eor r1, r1
    124: 1f be       out 0x3f, r1 ; 63
    126: cf ef       ldi r28, 0xFF ; 255
    128: d2 e0       ldi r29, 0x02 ; 2
    12a: de bf       out 0x3e, r29 ; 62
... blah blah
And further down after a lot of FFs:
   3000: 4b c0       rjmp .+150     ;  0x3098
   3002: 00 00       nop
   3004: 64 c0       rjmp .+200     ;  0x30ce
   3006: 00 00       nop
   3008: 62 c0       rjmp .+196     ;  0x30ce
   3098: 11 24       eor r1, r1
   309a: 1f be       out 0x3f, r1 ; 63
   309c: cf ef       ldi r28, 0xFF ; 255
   309e: d2 e0       ldi r29, 0x02 ; 2
   30a0: de bf       out 0x3e, r29 ; 62
   30a2: cd bf       out 0x3d, r28 ; 61
   30a4: 11 e0       ldi r17, 0x01 ; 1
   30a6: a0 e0       ldi r26, 0x00 ; 0
Looks like something. And is that a bootloader at the bottom? Who knows?
Now if you have a replacement .hex file (eg. firmware.hex in my example), you should be able to flash it like this:
Code: [Select]
avrdude -c usbtiny -p m16u2 -U flash:w:firmware.hex
The new firmware file should look something like this inside:
Code: [Select]
:2000000090C00000A9C00000A7C00000A5C00000A3C00000A1C000009FC000009DC00000DB
:200020009BC0000099C0000097C0000048C400000CC4000091C000008FC000008DC00000EC
:200040008BC0000089C0000087C0000085C0000083C0000081C000007FC0000002C10000FA
:200060007BC0000079C0000077C0000075C0000073C0000071C000006FC000006DC00000E0
Don't blame me if this goes wrong, but this is a pointer to the direction you might take.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
spycatcher2k
Attached is the patch for windows version - extract to the location of avrdude.conf & run patch.bat
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
