Topic: XY Plotter/CNC style interpolation project. Need great deal of help (Read 47830 times) previous topic - next topic
breegeek
Hello all,
I am working on what is for me a huge project to move an object around on a table from underneath using an XY Plotter.
The set up is basically an object (with a magnet on its bottom), atop a table. Under the table is a hidden XY Plotter bed moving around a corresponding magnet on the plotter's head. I am using two NEMA high torque stepper motors and Arduino.
So far:
- I have the architecture of the plotter set up (it's a pulley and spool system)
- I have the two stepper motors spinning
- I have Arduino able to talk to the motors (using stepper.h and simple code from Tom Igoe)
- I can get Processing to send signals to Arduino (so that I can test motion through keyboard commands)
- I can move them around and do simple things. Here's a video of me trying to make it draw a "circle": http://vimeo.com/38660151
- I own, but have not installed, 6 limit switches
Here's where I need guidance with:
1. Interpolation: right now, my code (which is in its current incarnation here: http://breerubinmfadt.tumblr.com/post/19749648817/current-code )is very rudimentary.
My coding skills are pretty slim and I can *kind* of suss out how to interpolate by running the motor a few steps one way and then running the other motor, getting pathetic-looking "pixelated" shapes (if you watch the video, you will see how non circular my circle is).
  • 1a.I found http://arduino.cc/forum/index.php?topic=93706.0 this topic on moving two motors "seemingly" at the same time, but I don't fully understand how to create smoother interpolation.
  • 1b. In addition to moving in one direction, how do I get the code to interpolate into a circular fashion? I want to be able to move the thing around in tight circles
2. Interrupting the code
This part relates to the whole project being an interactive piece. At certain points in its routines, I want the routines to be interrupted if a proximity sensor detects a person in the room, and then it will go into other routines. For example, if it's circling casually, and a user enters the room, it stops, appears to think, and then slowly moves "toward" the person in the room. I'm going to do this with OpenCV, so I have to have the computer send 'interrupts' into the routines. At the moment, I have the code running through Processing, so that if I press a key, the motors will spin in a certain routine, but I cannot interrupt them by pressing a key until the routine is done.
  • 2a. How do I make it so that, at any point in a given "routine", the action can be stopped based on a signal?
  • 2b. How do I get the limit switches to also send interrupts?
Anyway, I know there're a lot of questions here, but maybe some of you gurus have answers/guidance for me? That would be super amazing!
The project blog is here, in case you're curious: http://breerubinmfadt.tumblr.com/
Cheers in advance!!!
kf2qd
You might take a look at GRBL which is CNC code for Arduino.
sirbow2
#2
Mar 23, 2012, 05:32 am Last Edit: Mar 23, 2012, 05:36 am by sirbow2 Reason: 1
1b/1a: this will help you in creating circles:
Code: [Select]
for (int i = 0; i < [somenumber]; i++)
    angle = i*2*3.14/100;
    Xpos = 250 + (cos(angle) * Rad);
    Ypos = 250 + (sin(angle) * Rad);
//Move x motor to xpos
//move y motor to ypos
//it does this for each point of the circle, so you dont have to run them at the same time
2a. see next line, while loop maybe?
2b. button interrupts: http://arduino.cc/it/Reference/AttachInterrupt
http://dduino.blogspot.com all my Arduino/electronic projects!!!
{NEW} Getting Started, Learning, Reference + FAQ PDF!!:
[url]http://ar
breegeek
stimmer
1a: What you are looking for is called "Bresenham's Algorithm". Google will tell you a lot more, it's one of the most famous algorithms in computer science.
1b: There is also "Bresenham's circle algorithm" but I do not recommend it. Instead, use the code by sirbow2 above to turn the circle into straight lines.
2a: What I usually do is to have a variable called "stop", initially 0, and in every loop which needs it I have the line: if(stop) break;
Then in every loop you need to check whether you need to stop or not, eg if(bigRedStopButtonPressed())stop=1;
2b: Don't use interrupts, instead read the limit switch every time the stepper steps. It won't change at any other time  ;)
breegeek
sirbow and stinner: Should I be tracking xpos and ypos somehow? Just add to them each time I spin the steppers?
Also, is there a way to interrupt beyond the limit switch? Because I will also have behavior where, when someone interacts with the project, the routine is interrupted. Is there a way to make that break?
sirbow2
that code for the circle gives x/y coordinates, so, you need to keep track of where the stepper is in terms of x/y then subtract the current pos minus the goal position found by the equation, to find how many steps you need to move. So:
Code: [Select]
//draw circle at x,y 50,50
CircleXCenter = 50;
CircleYCenter = 50;
CurXPos = ??; //where the platform currently is in X
CurYPos = ??; //where the platform currently is in Y
    Xpos = CircleXCenter + (cos(angle) * Rad);
    Ypos = CircleYCenter + (sin(angle) * Rad);
    if(CurXPos < Xpos)
           MoveXNow = Xpos - CurXPos;
         MoveXNow = CurXPos - Xpos;
    if(CurYPos < Ypos)
          MoveYNow = Ypos - CurYPos;
          MoveYNow = CurYPos - Ypos;
   step(MoveXNow);
   step(MoveYNow);
             //<100, so -1
   if(i == (somenumber-1)) //we are at end of for loop, save current position.
       CurYPos = Ypos;
       CurXPos =Xpos ;
[url]http://ar
udoklein
Quote
2b: Don't use interrupts, instead read the limit switch every time the stepper steps. It won't change at any other time  smiley-wink
This is only true in theory. It relies on the assumption that the only possible movement is due to the controller sending a signal to the motor. Unfortunately this is only true 99% of the time.
Check out my experiments http://blog.blinkenlight.net
breegeek
sirbow2, thanks so much for the recontextualizing of that circle code; I have a hard time interpreting algorithms into code...
I am making a bit of progress, but am still having trouble with the switches. *where* do I put the logic to check them? I have the code reading the switches, but it doesn't stop the motors. Any ideas?
Also, how do I buy you guys a beer? <3
Code: [Select]
/* Stepper Motor Controller ;  language: Wiring/Arduino
This program drives a unipolar or bipolar stepper motor.  by Tom Igoe */
/* significant help from arduino superstars: sirbow2,
#include <Stepper.h>
#define motorSteps 200     // change this depending on the number of steps
#define motor2Steps 200     // change this depending on the number of steps
// per revolution of your motor
#define motorPin1 2
#define motorPin2 3
#define motorPin3 4
#define motorPin4 5
#define motorPin6 8
#define motorPin7 9
#define motorPin8 10
#define motorPin9 11
int reading = 0;
int previous = LOW;
long time = 0;         // the last time the output pin was toggled
long debounce = 50;   // the debounce time, increase if the output flickers
int state = HIGH;
//set pin numbers
int xStopMax = A3;
int xStopMin = A2;
int yStopMin = A1;
int yStopMax = A0;
int xPos;
int yPos;
boolean xIs0;
boolean xIsMax;
boolean yIs0;
boolean yIsMax;
// initialize of the Stepper library:
Stepper yAxis(motorSteps, motorPin1,motorPin2, motorPin3, motorPin4);
Stepper xAxis(motor2Steps, motorPin6,motorPin7, motorPin8, motorPin9);
  // set the motor speed at 60 RPMS:
  xAxis.setSpeed(60); //x
  yAxis.setSpeed(60); //y
  //set limit switches to analog inputs
  pinMode(xStopMin, INPUT);
  // Initialize the Serial port:
  //check limit switches
  if(digitalRead(xStopMin) == HIGH){
    xIs0 == true;
  else xIs0 == false;
  if(digitalRead(xStopMax) == HIGH){
    xIsMax == true;
  else xIsMax == false;
  if(digitalRead(yStopMin) == HIGH){
    yIs0 == true;
  else yIs0 == false;
  if(digitalRead(yStopMax) == HIGH){
    yIsMax == true;
  else yIsMax == false;
  char val=0;
  if(Serial.available()) val = Serial.read();
  //keyboard control
  switch(val){
  case 'N':
    Serial.read();
      moveN(200);
  case 'S':
    Serial.read();
      moveS(200);
  case 'E':
    Serial.read();
      moveE(200);
  case 'W':
    Serial.read();
      moveW(200);
    //diagonal (moving motors almost at the same time)
  case 'J': //NE
    Serial.read();
          moveNE(200);
  case 'H': //NW
     Serial.read();
          moveNW(200);
  case 'X': //SE
    Serial.read();
          moveSE(200);
  case 'Z': //SW
     Serial.read();
          moveSW(200);
  case 'C': //SW
     Serial.read();
          moveCirc();
  default:
    Serial.read();
    delay(10);
void moveE(int numSteps){
  //straight up down left right
    for(int s=0; s<numSteps; s++){
      xAxis.step(1);//moves arm AWAY from motors (takes 1800_ at 60 speed) to traverse the whole bed
  delay(100);
void moveW(int numSteps){
      xAxis.step(-1);
  delay(100);
void moveN(int numSteps){
      yAxis.step(1);
  delay(100);
void moveS(int numSteps){
      yAxis.step(-1);
  delay(100);
//diagonals
void moveNE(int numSteps){
      yAxis.step(1);
      xAxis.step(1);
  delay(100);
void moveSE(int numSteps){
      yAxis.step(-1);
      xAxis.step(1);
  delay(100);
void moveSW(int numSteps){
      yAxis.step(-1);
      xAxis.step(-1);
  delay(100);
void moveNW(int numSteps){
      yAxis.step(1);
      xAxis.step(-1);
    delay(100);
void moveCirc(){
    int CircleXCenter = 10;
    int CircleYCenter = 10;
    int CurXPos = xPos; //where the platform currently is in X
    int CurYPos = yPos; //where the platform currently is in Y
    int Rad = 20;
    for (int i = 0; i < 200; i++)
        int angle = i*2*3.14/100;
        xPos = CircleXCenter + (cos(angle) * Rad);
        yPos = CircleYCenter + (sin(angle) * Rad);
        if(CurXPos < xPos)
               xAxis.step(xPos - CurXPos);
              //movexnow = Xpos - CurXPos;
               xAxis.step(CurXPos - xPos);
           //MoveXNow = CurXPos - Xpos;
        if(CurYPos < yPos)
               yAxis.step(yPos - CurYPos);
             //   MoveYNow = Ypos - CurYPos;
               yAxis.step(CurYPos - yPos);
              //MoveYNow = CurYPos - Ypos;
       //step(MoveXNow);
       //step(MoveYNow);
                 //<100, so -1
       if(i == (200-1)) //we are at end of for loop, save current position.
           CurYPos = yPos;
           CurXPos = xPos ;
stimmer
One way would be to check the relevant end stop before making each step, eg:
Code: [Select]
      if(digitalRead(xStopMax) == HIGH) break; // break out of the loop if arm is already at the end stop
  delay(100);
and similar for all the other places the motors are stepped.
sirbow2
#10
Mar 28, 2012, 10:29 pm Last Edit: Mar 28, 2012, 10:34 pm by sirbow2 Reason: 1
Quote
i ran into the same issues when attempting to draw circles :P
Code: [Select]
you have "xStopMin" for all those :P should be:
Code: [Select]
//set limit switches to DIGITAL inputs
pinMode(xStopMax, INPUT);
pinMode(yStopMin, INPUT);
pinMode(yStopMax, INPUT);
why this?
Code: [Select]
  delay(100);
thats the same as
Code: [Select]
  xAxis.step(numSteps);//moves arm AWAY from motors (takes 1800_ at 60 speed) to traverse the whole bed
  delay(100);
right?
these are good though, need the one step at a time :):
Code: [Select]
//diagonals
      yAxis.step(1);
      xAxis.step(1);
  delay(100);
for the buttons, just make them interrupts(http://arduino.cc/playground/Main/PinChangeInt); this allows you to use A0-5 as interrupts. you also need to debounce them(fix the hardware error in side the switch) http://dduino.blogspot.com/2012/03/arduino-button-debouncing.html i suppose you could just do regular button debouncing in the loop, but that would waste processing time each loop, whereas interrupts wouldn't.
let me know if you need help with this.
for checking switch status and stoppign the steppers when need be try this:
Code: [Select]
int s = 0;
while(xMinBtn ==false && xMaxBtn ==false && s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
      s++;
  delay(100);
[url]http://ar
breegeek
Stimmer: the code worked fairly well with the if statements;
Also thanks for catching the blurry-eyed mistake I made with setting the input pins (or not)
sirbow2: I tried the while loop you gave me in the last post, but the limit switches didn't seem to stop the turning of the motor. Any ideas?  I only changed it for the E (moving East) code, and JUST IN CASE I messed up on my order, tried all four switches, but nothing stopped the motor from trying to spin.
Code: [Select]
/* significant help from arduino forum superstars: sirbow2, stimmer
#define motorPin1 2
#define motorPin2 3
#define motorPin3 4
#define motorPin4 5
#define motorPin6 8
#define motorPin7 9
int reading = 0;
int previous = LOW;
int state = HIGH;
//set pin numbers
int xStopMax = A1;
int xStopMin = A0;
int yStopMin = A2;
int yStopMax = A3;
int xPos;
int yPos;
boolean xIs0;
boolean xIsMax;
boolean yIs0;
boolean yIsMax;
    xIs0 == true;
    Serial.println("xMin");
  else xIs0 == false;
    xIsMax == true;
    Serial.println("xMax");
    yIs0 == true;
    Serial.println("yMin");
  else yIs0 == false;
    yIsMax == true;
    Serial.println("yMax");
  char val=0;
  //keyboard control
  switch(val){
  case 'N':
    Serial.read();
      moveN(200);
  case 'S':
    Serial.read();
      moveS(200);
  case 'E':
    Serial.read();
      moveE(200);
  case 'W':
    Serial.read();
      moveW(200);
  case 'J': //NE
    Serial.read();
          moveNE(200);
  case 'H': //NW
     Serial.read();
          moveNW(200);
  case 'X': //SE
    Serial.read();
          moveSE(200);
  case 'Z': //SW
     Serial.read();
          moveSW(200);
  case 'C': //SW
     Serial.read();
          moveCirc();
  case 'Q': //reset to 0,0
     Serial.read();
         while(xStopMin != true && yStopMin != true);
         moveN(100);
         moveE(100);
  default:
    Serial.read();
    delay(10);
//movement functions
  //first, straight up down left right
  int s = 0;
  while(xIs0 ==false && xIsMax ==false && s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
        xAxis.step(-1);
        s++;
    delay(100);
      else xAxis.step(1);
  delay(100);
      if(digitalRead(yStopMin) == HIGH) break;
      else yAxis.step(-1);
  delay(100);
      if(digitalRead(yStopMax) == HIGH) break;
       else yAxis.step(1);
  delay(100);
//diagonals
      if(digitalRead(xStopMax) == HIGH || digitalRead(yStopMax) == HIGH) break;
      else{
        yAxis.step(-1);
       xAxis.step(-1);
  delay(100);
     else{yAxis.step(-1);
      xAxis.step(1);
  delay(100);
      if(digitalRead(xStopMin) == HIGH || digitalRead(yStopMin)) break;
      yAxis.step(-1);
      xAxis.step(-1);
  delay(100);
      if(digitalRead(xStopMin) == HIGH) break;
      yAxis.step(-1);
      xAxis.step(1);
    delay(100);
void moveCirc(){
    int Rad = 20;
        if(CurXPos < xPos)
        if(CurYPos < yPos)
       //step(MoveXNow);
       //step(MoveYNow);
                 //<100, so -1
           CurYPos = yPos;
           CurXPos = xPos ;
Also, I tried the arduino example debounce code, but the logic has it set the switch to high only once when it's been hit; I need it to be persistent, just in case the arm is still hitting the switch.
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
breegeek
ALSO:
I am having trouble keeping track of xPos and yPos. I am trying to keep track of them when I step my motor.
Any ideas?
Code: [Select]
#define motorPin1 2
#define motorPin2 3
#define motorPin3 4
#define motorPin4 5
#define motorPin6 8
#define motorPin7 9
int reading = 0;
int previous = LOW;
int state = HIGH;
//set pin numbers
int xStopMax = A1;
int xStopMin = A0;
int yStopMin = A3;
int yStopMax = A2;
int xPos;
int yPos;
boolean xIs0;
boolean xIsMax;
boolean yIs0;
boolean yIsMax;
  xPos = 0;
  yPos = 0;
    xIs0 == true;
    xPos = 0;
  else xIs0 == false;
    xIsMax == true;
    yIs0 == true;
    yPos = 0;
  else yIs0 == false;
    yIsMax == true;
  char val=0;
  //keyboard control
  switch(val){
  case 'N':
    Serial.read();
      moveN(200);
  case 'S':
    Serial.read();
      moveS(200);
  case 'E':
    Serial.read();
      moveE(200);
  case 'W':
    Serial.read();
      moveW(200);
  case 'J': //NE
    Serial.read();
          moveNE(200);
  case 'H': //NW
     Serial.read();
          moveNW(200);
  case 'X': //SE
    Serial.read();
          moveSE(200);
  case 'Z': //SW
     Serial.read();
          moveSW(200);
  case 'C': //SW
     Serial.read();
          moveCirc();
  //resets
     Serial.read();
         moveN(100);
         moveE(100);
//debugs
   case 'P':
     Serial.read();
       Serial.print("x position: ");
       Serial.println(xPos);
       Serial.println("y position: ");
       Serial.println(yPos);
  default:
    Serial.read();
    delay(10);
  //first, str  aight up down left right
      if(digitalRead(xStopMin) == HIGH) break; // break out of the loop if arm is already at the end stop
  xPos += numSteps;
      else xAxis.step(-1);
  xPos += -numSteps;
  yPos += -numSteps;
       else yAxis.step(1);
    yPos += -numSteps ;
//diagonals
      else{
        yAxis.step(-1);
       xAxis.step(1);
  //////////////delay(100);
      xAxis.step(1);
      yAxis.step(1);
      xAxis.step(-1);
      yAxis.step(-1);
      xAxis.step(-1);
void moveCirc(){
    int CircleXCenter = 2;
    int CircleYCenter = 2;
    int Rad = 1;
    for (int i = 0; i < 360; i++)
       float
       angle = i*2*3.14/360;
        if(CurXPos < xPos)
        if(CurYPos < yPos)
      // step(xAxis);
       //step(yAxis);
                 //<100, so -1
       if(i == (360-1)) //we are at end of for loop, save current position.
           CurYPos = yPos;
           CurXPos = xPos ;
sirbow2
#13
Mar 29, 2012, 10:16 pm Last Edit: Mar 29, 2012, 10:24 pm by sirbow2 Reason: 1
Quote
because its not reading the button value every loop of the while. that code was meant for interrupts.
this could be a quick fix while you get interrupts working:
Code: [Select]
int s = 0;
while(!digitalRead(xStopMin) && !digitalRead(xStopMax)&& s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
     s++;
 delay(100);
for keeping track of positon these look good:
Code: [Select]
 xPos += numSteps;
 xPos += -numSteps;
maybe xPos -=numSteps; on the last one instead of xPos += -numSteps; but either way they should work...
Quote
more specific please
[url]http://ar
breegeek
Thanks for the reply!
I am having trouble tracking xpos and ypos. For example, I advance the motors a bit to a position, and then I call up a read out of xPos and yPos and it always tells me they are at (0,0)...
I think (am I right?) that I correctly have to ascertain the xPos and yPos in order for the circle code to work, because it relies on knowing where it is?
Here's the current code:
Code: [Select]
#define motorPin1 2
#define motorPin2 3
#define motorPin3 4
#define motorPin4 5
#define motorPin6 8
#define motorPin7 9
int reading = 0;
int previous = LOW;
int state = HIGH;
//set pin numbers
int xStopMax = A1;
int xStopMin = A0;
int yStopMin = A3;
int yStopMax = A2;
int xPos;
int yPos;
boolean xIs0;
boolean xIsMax;
boolean yIs0;
boolean yIsMax;
  xPos = 0;
  yPos = 0;
    xIs0 == true;
    xPos = 0;
  else xIs0 == false;
    xIsMax == true;
    yIs0 == true;
    yPos = 0;
  else yIs0 == false;
    yIsMax == true;
  char val=0;
  //keyboard control
  switch(val){
  case 'N':
    Serial.read();
      moveN(200);
  case 'S':
    Serial.read();
      moveS(200);
  case 'E':
    Serial.read();
      moveE(200);
  case 'W':
    Serial.read();
      moveW(200);
  case 'J': //NE
    Serial.read();
          moveNE(200);
  case 'H': //NW
     Serial.read();
          moveNW(200);
  case 'X': //SE
    Serial.read();
          moveSE(200);
  case 'Z': //SW
     Serial.read();
          moveSW(200);
  case 'C': //SW
     Serial.read();
          moveCirc();
  //resets
     Serial.read();
         moveN(100);
         moveE(100);
//debugs
   case 'P':
     Serial.read();
  default:
    Serial.read();
    delay(10);
    int s = 0;
    while(!digitalRead(xStopMax)&& s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
          xAxis.step(1);
          s++;
      delay(100);
    xPos += numSteps;
     int s = 0;
    while(!digitalRead(xStopMin)&& s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
          xAxis.step(-1);
          s++;
      delay(100);
    xPos -= numSteps;
   int s = 0;
    while(!digitalRead(yStopMax)&& s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
          yAxis.step(-1);
          s++;
      delay(100);
    yPos += numSteps;
  int s = 0;
    while(!digitalRead(yStopMin)&& s<numSteps)//checks the button each step, also checks to see if it has moved s amount of steps
          yAxis.step(1);
          s++;
      delay(100);
    yPos -= numSteps;
//diagonals
  int s=0;
  while(!digitalRead(xStopMax) && !digitalRead(yStopMin) && s<numSteps);
        yAxis.step(-1);
        xAxis.step(1);
   xPos += numSteps;
   yPos -= numSteps;
   int s=0;
  while(!digitalRead(xStopMax) && !digitalRead(yStopMax) && s<numSteps);
        yAxis.step(1);
        xAxis.step(1);
   xPos += numSteps;
   yPos += numSteps;
  int s=0;
    while(!digitalRead(xStopMin) && !digitalRead(yStopMax) && s<numSteps);
          yAxis.step(1);
          xAxis.step(-1);
   xPos -= numSteps;
   yPos += numSteps;
  int s=0;
    while(!digitalRead(xStopMin) && !digitalRead(yStopMin) && s<numSteps);
          yAxis.step(-1);
          xAxis.step(-1);
   xPos -= numSteps;
   yPos -= numSteps;
void moveCirc(){
    int Rad = 1;
       float
        if(CurXPos < xPos)
        if(CurYPos < yPos)
      // step(xAxis);
       //step(yAxis);
                 //<100, so -1
           CurYPos = yPos;
           CurXPos = xPos ;
