Topic: Temperature sensor & LED (Read 1 time) previous topic - next topic
rob_dphillips
I am trying to get different LED's to turn on when the temperature reaches different temps.
anyone lend a hand?
//TMP36 Pin Variables
int temperaturePin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
                        //the resolution is 10 mV / degree centigrade
                        //(500 mV offset) to make negative temperatures an option
* setup() - this function runs once when you turn your Arduino on
* We initialize the serial connection with the computer
  Serial.begin(9600);      //Start the serial connection with the copmuter
                           //to view the result open the serial monitor
                           //last button beneath the file bar (looks like a box with an antenae)
void loop()                     // run over and over again
float temperature = getVoltage(temperaturePin);  //getting the voltage reading from the temperature sensor
temperature = (temperature - .5) * 100;          //converting from 10 mv per degree wit 500 mV offset
                                                  //to degrees ((volatge - 500mV) times 100)
Serial.println(temperature);                     //printing the result
{ pinMode(LEDPIN,OUTPUT); //waiting a second}
* getVoltage() - returns the voltage on the analog input defined by
* pin
float getVoltage(int pin){
return (analogRead(pin) * .004882814); //converting from a 0 to 1023 digital range
   // to 0 to 5 volts (each 1 reading equals ~ 5 millivolts
pinMode(ledPins [2],OUTPUT);
pinMode(ledpins [4],OUTPUT);
if (analogueRead(0) < 22.75)
digitalWrite(2, High);
else (temperaturePin >22.75){
digitalWrite(LEDpin4, High);
